Unread 05-24-2016, 01:18 PM   #1
Tykenny
Saltillo tile drivway
Hi
I have read in the past forums on Saltillo tile for driveway.
I am wanting to go in this direction, so I must lay tile on concrete?
And do I use same grout as interior?
(I seal the tiles well, 5 coats pre-installation and 5 coats post installation- any other advice)?
Colleen
Tykenny is offline   Reply With Quote
Unread 05-24-2016, 02:11 PM   #2
Lazarus
Lazarus's Avatar
I would think you should be OK over a cured, concrete driveway...never having done one, myself.
The grout should be a sanded grout....interior might be alright but I recall the Saltillo, with the typical wide joints, needs a special, concrete-heavy grout.
Hopefully, some others can chime in on this.....
Laz...
Unread 05-25-2016, 10:25 AM   #3
Tykenny
Thanks, Hoping to hear from others.
Colleen
Unread 05-25-2016, 03:22 PM   #4
jcsa
Tile Contractor
Saltillo on Driveway
Colleen,
We are in the heart of Saltillo world here in San Antonio Texas. I have set thousands of feet of this material. Some things to think about before installing Saltillo. First it is a soft clay. Because of its softness it will wear from the weight of tires and vehicles. It is porous even when sealed. Efflorescence can occur and turn the tiles white under the sealer. This is caused from moisture from rain and sprinkler systems. Also i do not know where you live, freeze thaw are considerations that need to be thought out carefully. If water gets inside the body of the tile and it freezes, it will literally blow the tiles apart.
Sorry to give you what you may not have wanted to hear, but the facts are necessary. There is a tile that is much denser, D'hanis tile. It is red in color and fired at a much higher temperature and less porous. It will wear well under the conditions. It is about the same price as a decent saltillo. It is made in D'hanis Texas. Look up their website fro more information. Let me know if i can help Sincerely John Cox
JC
Certified Tile Installer # 26
Cox Tile, Inc.
jcsa is offline   Reply With Quote
Saltillo tile? SpursGirl Cleaning, Restoration and Sealing 3 01-07-2012 11:27 PM
Old Saltillo tile Hector Macias Tile Forum/Advice Board 4 09-30-2006 09:35 PM
Saltillo Tile FreeBlaze Tile Forum/Advice Board 1 11-22-2004 02:54 PM
Sanded or Saltillo Grout for Saltillo Neverending Tile Forum/Advice Board 9 08-30-2004 10:26 AM
Saltillo Tile AnnaLeeF Cleaning, Restoration and Sealing 4 05-24-2004 04:15 PM
