Unread 10-04-2016, 06:13 AM   #31
I guess the mud and heat wires are still in place. It's hard to tell but the scrap tiles don't seem to have very much thinset on the backs. I could be wrong. That might be a good thing this time but if the tiles are bonded well, the mud would usually come up with the tiles.
Unread 10-04-2016, 07:04 AM   #32
jcsa
Tile Contractor
Floor Heating
I would check your floor heating for continuity after the tile removal. You need to establish that that is good. You can test it with a ohms meter. The label will give you what your ohms should be when you test it. If you don't understand you may have to get an electrician to perform the test. You do not want to install the new tile before this is done. If there are some breaks, it is possible to repair them and salvage the floor heating. If there are numerous breaks, you will have to replace the floor heating. Did not want to add to the issue, but it is necessary to do this. John Cox
JC
Certified Tile Installer # 26
Cox Tile, Inc.
jcsa is offline   Reply With Quote
Unread 10-04-2016, 03:59 PM   #33
What's even better than just an ohm's check, is a megometer. That not only tests the continuity, but also the state of the insulation. If a wire's insulation is damaged, it may still have continuity, but could fail down the road. An ohmmeter won't test that.
Unread 10-05-2016, 02:43 PM   #34
babyduck
Thanks ever so much for the information, we will definitely check out the heating cables. They busted up the tiles Monday which separated from the thinset without any damage to the drypack - which is good. They have spent since Monday afternoon grinding down the thinset and still are not done with that. But they are going to leave us high and dry in scrounging to find someone else to finish the job. Not a particularly attractive characteristic. I have told him mistakes happen - the upstairs is beautiful - lets just learn, be gentle next time, pay attention to what you are doing and move on. But no dice. Uggghh.
Rebecca
babyduck is offline   Reply With Quote
Unread 10-05-2016, 06:50 PM   #35
ZZZK
Do you have to eat the cost of the tile? Also, I can't believe ALL those tiles came out so clean? Doesn't seem like he burned in/back buttered any thinset into those tiles...
John
Unread 10-25-2016, 07:18 AM   #36
babyduck
Saga Continues - Now I think I have OPTICAL HAZE - Arrrgh - it is horrific!
First Tile setter used perfect 24 x 24 glazed porcelain dark brown tiles - beautiful in fact and fully reflective. He damaged a good number of them, 60% of the 83 that were laid), chipping and scarring the edges upon cleaning the grout joints so they had to be all ripped up. As such we had to buy another batch of tiles and had another tile setting company lay them - of course this was a different lot number as the first set was bought months ago and of course they are different in color. First ones were milk chocolate and second batch were more dark chocolate and of course no one noticed it as they were being laid and I did not check prior (stupid me.) .... so I have both tiles spread out over the floor. I can live with the color issue as there is so much movement in the tile a normal person probably wont really notice .... however the new batch has this awful optical haze all over the tile. At least I think this is what it is. It is dramatically worse when the sunlight hits it. There are 4 big windows so sunlight just floods in. They have not yet been grouted so it is definitely NOT grout haze. I would like to know what I can do that is not very expensive in order to get them to not look so hazy/dirty. I don't think it is a coating. When the sunlight hits the floor on one from the first batch it is absolutely beautiful the next one which is second batch looks horrific. Am I SOL and should just buy curtains. Cant believe this is such a nightmare - so mad at myself for not checking them first.
Rebecca
Unread 10-25-2016, 07:32 AM   #37
Autoplay
Tile Setter
When you say optical haze.......does it look like circular swirl marks on top of tile?
Pictures would help diagnosing what you're describing. Just guessing from what you stated,sounds like polish lines on top of your porcelain.
Rich
Autoplay is offline   Reply With Quote
Unread 10-25-2016, 07:44 AM   #38
tatumjonj
I've never heard the term optical haze. What is it?
Jon
Unread 10-25-2016, 08:12 AM   #39
babyduck
Below are the photos - both tiles are cleaned and I have them sitting outside in the sunlight taking a picture at various angles. Obviously one on the left is the old stock and one on the right is the new stock. Until they were cleaned we never noticed the problem. Now the whole floor is laid - not yet grouted - and it is hideous. Cant afford to rip them up again.
Rebecca
Unread 10-25-2016, 08:17 AM   #40
Just1
I believe that has to do with the different dye lot numbers. Different lot numbers can not only change the color of the tile but also the sheen and I think that is what is going on here.
Just1 is offline   Reply With Quote
Unread 10-25-2016, 08:18 AM   #41
Just1
If the first installer chipped your tiles, he should have paid for new ones.
Unread 10-25-2016, 08:34 AM   #42
Autoplay
Tile Setter
IMO,it's pretty drastic,the difference between the two. Again IMO,it looks like a finish polish issue,or lack there-of.
How the current installers didn't see this while installing,is beyond me????
Need to move where you live. I could corner the market with passable installs!
Rich
Unread 10-25-2016, 08:40 AM   #43
Autoplay
Tile Setter
To possibly aid you......try doing a test with this......take some 1500,2000,and 3000 grit sandpaper,and see if the sheen/finish is enhanced by doing such. Use the sandpaper wet. If that works,is acceptable etc.....possibly seek a company that does marble restoration etc,and have em polish up the floor.
You could try a topical too,but will enhance the polish swirls you currently have.
Rich
Unread 10-28-2016, 02:55 AM   #44
The non-uniformity makes it look like surface damage. What does the supplier say?
Unread 10-28-2016, 11:21 AM   #45
babyduck
Supplier is trying to say anything that makes them not responsible. Moving forward though we are having to rip it up ... again. About 550 square feet. The problem is the thinset. It is over top of a dry packed floor with heating cables. We will check to ensure that the cables are not damaged - but what is the best method to grind down the thinset?
Rebecca
cracked porcelain floor tiles Kippee Tile Forum/Advice Board 23 03-24-2019 12:06 PM
Porcelain flooring installation on cracked concrete GaryQ Tile Forum/Advice Board 7 09-25-2018 04:19 PM
Cracked Slab Thus Cracked Tile Reginald Tile Forum/Advice Board 9 04-06-2017 06:35 PM
cracked grout can it be expired grout causing this? please help frustratedhomeowner Tile Forum/Advice Board 7 06-22-2010 02:48 PM
One cracked Porcelain Tile -Diagonal Chanceg Tile Forum/Advice Board 1 10-06-2009 08:38 PM
