Unread 10-12-2020, 06:10 AM   #31
vlocka
A properly installed liner IS the waterproofing of a conventionally built shower...the top surface is not then later waterproofed. Tile is the decorative, wear surface, and some moisture is expected to get beneath it. In a conventional shower, that's into the setting mud bed on top of the liner. If you use a sheet membrane
Hey jadnashua, so I'm guessing you just posted without reading the previous conversations. We already went over all this.
I'm doing a pre slope and new liner over the curb etc etc.
My question is for the walls. What should I use to waterproof it?
Again I have certainteed diamondback backer board
I will have a mud pan if that helps with any info.
v
vlocka is offline   Reply With Quote
Unread 10-12-2020, 06:52 AM   #32
e3
Post
See post #13-15-16- 20-21-24-25-27...
Eric
Noble Company
Unread 10-12-2020, 07:35 AM   #33
vlocka
Ahh thank you. I forgot that you said that.
I will keep you guys updated.
Preslope will be getting done today.
v
Unread 10-19-2020, 04:03 PM   #34
vlocka
Tile edge not flush with drywall
My shower is now warped a bit which left my tile edge not flush with the drywall. What is a good way to fix this gap? Its half inch off at the bottom and slowly becomes flush at the top of the wall.
v
Unread 10-19-2020, 05:31 PM   #35
vlocka
Here is another angle
v
Unread 10-19-2020, 05:32 PM   #36
vlocka
Another angle
v
Unread 10-19-2020, 08:21 PM   #37
Hi, V.
I know it’s late to ask why you didn’t install the profile flush with the wall and simply cut the tile to fit, but knowing why will help us understand options.
And another question: has the tile on the pan or the bottom course of tile been set with mastic?
Unread 10-20-2020, 04:23 AM   #38
vlocka
It's not flush with the wall because the wall is so off that the cuts in the shower would look so bad and off.
I'm not sure about the tile on the pan if he did it with mastic or not.
Now does anyone know how to fix this problem?
Can I just fill with mud??
v
Unread 10-20-2020, 08:14 AM   #39
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
I suspect all the pros here would advise that this should have been addressed at the framing and drywall stage...long before any tile was set.
I imagine one could patch in varying thicknesses of drywall and float with setting drywall compound and mesh tape in several lifts. This would require installing a new corner bead on that corner opposite the metal. I can almost guarantee it will look less than great. Ugggh.
Not something I could offer a client in good conscience, but stranger things have been done.
Peter
Unread 10-20-2020, 08:27 AM   #40
vlocka
So basically take off corner bead. Put half in drywall strip up the wall till it looks close to flush, install new corner bead , then mud and tape everything.
v
Unread 10-21-2020, 03:43 AM   #41
vlocka
waterproofing new shower window
How do i go about waterproofing a new vinyl window in a shower?
The casing and sill are all vinyl, also the window is fixed so it does not open or close.
v
Unread 10-21-2020, 07:38 AM   #42
Appears you've already finished tiling the wall around the window, V. Too late to do any waterproofing. You can use a flexible sealant in the gap between window and tile and stop some direct water entry for a time, but it won't be waterproof.
Unread 10-21-2020, 05:24 PM   #43
vlocka
Should i tile the inside of the window sill and around the inside of the frame to help and pitch the window still tile with a over hang?
v
Unread 10-23-2020, 06:46 AM   #44
vlocka
Is that vinyl snap on casing waterproof??
v
Unread 10-23-2020, 07:21 AM   #45
At this stage, you can do some topical sealant like CX mentioned. But if you wanted to do some waterproofing, you would have tied the window into the shower wall’s waterproofing before any tile was set. You see, it’s common for moisture from your shower to penetrate into the wall and into the tile assembly...so your bead of caulk can’t help. That’s why waterproofing needs to be done earlier.
That means that your other methods of using more tile or special casing doesn’t really afford additional protection over the caulk bead.
Ok to use DensShield on Walls and ceiling in entire bathroom toddmanqa Tile Forum/Advice Board 7 04-07-2012 10:08 AM
Tiling over painted ceiling in shower Toocool100 Tile Forum/Advice Board 14 03-05-2012 11:51 AM
Kerdi Membrane on painted drywall ulcus Tile Forum/Advice Board 2 11-18-2008 12:27 PM
Painted Plaster Walls & Ceiling Bathroom with EAVE HELP! FirstTimeHomeOwner Tile Forum/Advice Board 7 09-24-2007 05:29 PM
what caulk to use between tile wall and sheetrock painted ceiling in shower? cspronto Tile Forum/Advice Board 4 11-22-2006 08:07 PM
