Unread 04-12-2011, 04:47 PM   #1
Shawn Prentice
Exterior limestone repair advice
I guess I must have pissed someone/s here off to get 108 views and 2 responses. Thanks for the input.
Shawn Prentice is offline   Reply With Quote
Unread 04-12-2011, 07:41 PM   #2
Shawn, You can lift the loose stones and stick them back down but usually more stones will break loose as you are working. It looks like some of the pieces of the lower section are sinking in the soil, may not be on slab there.
Unread 04-12-2011, 08:14 PM   #3
Shawn Prentice
Thanks for the reply, Davy.
Unread 04-12-2011, 08:44 PM   #4
I would just re set the loose ones and point them with a sand & portland mixture.
I'm sure that's what was originally used and it was grout.
also all that cracking is probably prom water penetration and then it froze causing the cracking on more deterioration.
once you get it all fixed up I'm sure there is some type or solvent based sealer you can spray on them to polish it up and slow down the water penetration.
Unread 04-13-2011, 12:49 AM   #5
Shawn Prentice
Thanks much, Brian.
Unread 04-13-2011, 07:25 AM   #6
Shawn Prentice
Exterior grout repair project Mr. Nibbles Cleaning, Restoration and Sealing 7 04-23-2010 03:53 PM
Limestone Job - Need advice on options tkubik Tile Forum/Advice Board 32 02-21-2007 10:24 AM
Installing Limestone Tile on Exterior Concrete CAlandscaper Tile Forum/Advice Board 3 02-28-2006 09:48 AM
Limestone Floor Repair mangus Cleaning, Restoration and Sealing 4 06-14-2005 10:33 PM
repair exterior porch tile jeffrey Tile Forum/Advice Board 11 06-24-2003 08:36 PM
