Unread 08-14-2019, 07:48 AM   #1
Pamela
cut tile advice needed for a tricky layout
Attachment 209740I tiled myself into a corner and would appreciate some expertise on how best to handle it. These tiles are inexpensive, so I don't mind ripping out some rows if I can do it better.
Attached photo shows an outside corner and about 5" wall space until there is a cabinet. The corner tiles are mitred on one end and cut on the other end (cut short or cut long, depending on the row). On the rows with two tiles, the second tiles also have one finished end and one cut end.
Problems that I see:
1. the gap against the cabinet varies too much, IMO
2. there are cut ends meeting up with finished ends, which is not ideal but I can't really avoid it
Anyone want to describe how you would handle this situation? Moving the cabinet is not an option.
Pamela
Pamela is offline   Reply With Quote
Unread 08-14-2019, 09:25 AM   #2
john619
grout it and keep going. looks fine to me. I do not see much issue with the spacing to the cabinet
john
Unread 08-14-2019, 11:03 AM   #3
Elkski
Elkski's Avatar
I agree looks ok. I would imagine you will plan to put some flexible caulk along the cabinet joint and it looks like an easy nice Gap to fill.
Teddy
Unread 08-18-2019, 08:35 PM   #4
Tiger Mountain Tile Inc
We can only see three rows but it looks good to me. It looks like you are going for factory ends on the outside miter so there's no way to avoid a cut butting up to a finished end in the field. But it looks good the way that you've done it.
Jim Upton
DIYTileGuy
Tile layout advice needed for tub surround SStem Tile Forum/Advice Board 3 01-25-2018 08:24 AM
Design/Layout Advice Needed j.robinson389 Tile Forum/Advice Board 23 11-07-2017 06:36 PM
Hex Mosiac tile layout and grout advice needed KevinB Tile Forum/Advice Board 7 12-26-2013 08:41 PM
Tile Layout Advice Needed gimletmaker Tile Forum/Advice Board 20 02-11-2010 06:32 PM
tricky layout opiethetileman Professionals' Hangout 51 03-23-2007 07:29 PM
