Unread 07-20-2019, 09:32 AM   #1
TheAman
Mold at bottom corner of my shower
Dear Folks,
About a year ago I finished a small bath Reno/expansion. It was a tiny half-bath, now it is a tiny full bath (with toilet, sink, and shower rather than bathtub). I did the poured shower pan myself, but no vinyl liner underneath because I was planning to use Redguard for the waterproof layer. I put up the CBU on the walls, then two coats of Redguard on showerpan and 3/4 way up the walls. Then tiled showerpan with 2” (inch) square tiles, and walls with 1’ (ft) Sq tiles. At corners between walls and between walls and floor I used sanded caulk color-matched to the grout. Everything came out pretty well, considering it was my first time tiling., or so I thought. Now I have mold growing at the bottom back seam between the wall and the floor. Obviously, I have some water retention (“and painful bloating”) somewhere. What is my best course of action here? I would prefer not to redo the whole shower - that would be a painful learning experience. From what I had read I thought I did it right. I did not seal the grout, as my understanding was that the grout is porous, the porcelain tiles are porous, a little water seeps through and is channeled by the Redguard membrane down to the drain. Obviously, that is not happening as it should somewhere. Suggestions please?
Puzzled in NC,
Alvin
Sent from my iPad using Tapatalk
Alvin
TheAman is offline   Reply With Quote
Unread 07-20-2019, 10:15 AM   #2
Welcome to the forum, Alvin.
When you applied the Redgard, how was it applied, how many coats, and to what thickness? Did you use a wet film thickness gauge?
Did you use any reinforcement fabric or mesh on any of the seams?
Unread 07-20-2019, 10:16 AM   #3
Also, regarding the caulk in the corners, specifically what did you use?
Unread 07-20-2019, 10:18 AM   #4
Welcome, Alvin.
1. What drain did you use in the shower and how did you attach the RedGard to that drain?
2. How did you attach the wall tiles and with what adhesive? Did you use a spot-bonding method?
3. What caulk, very specifically (brand name, make and model) did you use at the changes of plane?
Photos are always helpful. Use the paper-clip icon above the Reply dialog box to attach photos from storage on your computer.
[Edit] Young Kevin is quick this morning, eh?
Unread 07-20-2019, 12:39 PM   #5
Welcome, Alvin.
Lotta good questions from these guys. Assuming the shower was built without problems that the answers to the previous questions would answer....you could just clean the caulk from time to time.
I personally don't like acrylic caulk (which is what sanded caulk is 99% of the time). It's nowhere near as flexible as silicone and when the walls move a tiny bit from themal and moisture changes, it separates from one side of the wall and allows moisture to harbor for a relatively long period of time. But you don't necessarily need water retention from a crack or from behind a tile assembly to get acrylic caulk to form mold. There's plenty of moisture and food (bar soap and dead skin flakes) for it to grow. For me, I'd swap out the acrylic caulk for 100% silicone (most silicones have a certain amount of mildewcide in them) and try to slightly improve the ventilation within the shower/bathroom (to reduce moisture, hence less mildew/mold).
Unread 07-20-2019, 02:40 PM   #6
And if the shower has been properly constructed, the best defense against mold is to have a properly sized and used exhaust fan in the bathroom.
Unread 07-20-2019, 04:00 PM   #7
If the seam ends up being very deep, rather than filling it all up with caulk, it usually ends up working better to use a foam backer rod stuffed in there with caulk on top. The backer rod must be sized properly. That way, the caulk ends up shaped more like an hour-glass versus a rectangular block which allows it to stretch in the narrow, middle area, and is therefore less likely to tear away from the surfaces. It also ends up using less caulk. The backer rod tends to be cheap in comparison to caulk.
Unread 07-21-2019, 06:40 AM   #8
Like the others said, a perfectly built shower can harbor mold if there's not enough ventilation. When not in use, keep the door open at least part way.
Unread 07-31-2019, 11:32 AM   #9
TheAman
Answers to some of these questions
Dear Folks,
Thanks for all the replies. I am sorry to be so long in getting back, I had some other things going on at the end of the summer term (I am a college teacher) and it took me some time to find the necessary info.
I will try to answer these questions in the order they came in, and I have taken some pictures as well.
1) Kman - I painted the Redguard on with a brush, I think, though I may have used a roller as well. I don't remember for sure, I think just a brush. If nothing else, it is expensive, and I felt I would lose a lot on a roller, but again, I am not sure. I did two coats, one all over the shower walls and floor, and one up about 3/4 of the way on the walls and floor (running out of Redguard). I did not use a wet film gauge, I did not know there was such a thing. I did have the reinforcement mesh on the seams of the cbu's on the wall.
2) Kman - For the caulk in the corners, I used sanded caulk to match the sanded grout used on the walls. I will include a picture of the label, it is made by TEC Invision. It does not say anything about acrylic on the label, but it does say mold and mildew resistant.
3) cx - The shower drain was just a pvc shower drain purchased at Lowes, with a square chromed insert that screws in. I grabbed a shot of it from their website. As I remember, you screw it into the wooden base of the shower, build the slopeing cement floor around it, and then tile the floor, and then put in the top insert. The Redguard was painted across the cement and into the drain, though when the insert was finally screwed into the base, it peeled much of that Redguard back out.
I attached the tiles with mortar, MAPEI porcelain tile mortar, polymer enriched thin-set. I put mortar on the cbu on the wall and also on the tile, using the trowel with the 3/8 inch teeth.
The caulk was mentioned above, made by TEC Invision. It was sold there with the grout with the same color designations.
4) Tool Guy - Kg - Just cleaning the caulk is not an option. That is exactly the problem. My wife washes the shower about every time she showers (she keeps a bottle of spray cleaner in there, and just wipes/scrubs it down before she gets out of the shower), and the mold is now in caulk seams in the bottom back corners and can't be scrubbed out. I like your idea of replacing the caulk with a silicone caulk, that would be a great fix if that works.
5) cx - There is an exhaust fan in the bathroom, though I confess I often do not use it. I don't like the noise of it. Someone suggested a switch with a cut-off timer, and that might be worth the investment, to let it run for 30min after a shower.
6) jadnashua - thanks for your comment about backer rod. I often see that mentioned but can never find that at the store. Regardless, I don't think the caulk is really thick in the seams in question, but I will look into it when I am pulling out the old stuff.
7) Davy - yes, the door is usually left open when not in use, it is a bathroom off the bedroom.
Alvin
Unread 07-31-2019, 01:15 PM   #10
makethatkerdistick
Hi Alvin. Fellow college teacher and amateur tiler here!
From your description on how you tied in the Redgard with the drain, I have concerns about the longevity of your assembly. You mention that you peeled Redgard off when you screwed in the drain. A water-tight seal between the Redgard and the drain flange is essential. Usually, there are much more reliable methods to provide a seal between drain and floor waterproofing. With a PVC liner, you get the clamping action of the drain plus sealant. With a proprietary bonding membrane in conjunction with a drain to match it, you get a factory-designed system that works together.
Yours wouldn't be my preferred method of waterproofing the shower floor. It could be fine but it could also cause leaks in the future. If you have access from below, you might want to check for leaks over time.
If you have water accumulation behind the tile and that is indeed causing your mold issues, then it's possible that you had insufficient thinset coverage when installing your tiles, in particular the bottom row. Do you remember how much coverage you got? Did you check during installation? If there are cavities behind your tile, that would support your suspicion of water accumulation.
Panasonic makes a line of bathroom fans (Whispergreen) that are awesome. DC motors that are very quiet and efficient. Well worth the money. I love mine.
It seems that your shower floor has some dirt, too. Is that mold as well, growing from the grout joints? Also, what did you mean by "bloating"? Is something swelling or shifting? if so, that would be a bad sign. The slope of your floor also looks a bit uneven. Do you get puddles of standing water that won't drain after taking a shower?
Wolfgang
Unread 07-31-2019, 02:25 PM   #11
speed51133
the instructions I have seen show using fiberglass cloth to embed the redgard into over the drain. You then clamp onto that. It gives it more bite.
https://youtu.be/9RJgvo8OIgo?t=263
try to ignore the horrendous looking speed bump!
Unread 07-31-2019, 04:12 PM   #12
Mike, please add some attribution to that quote so it's not confused with something CX posted, eh?
Unread 07-31-2019, 09:51 PM   #13
TheAman
To makethatkerdistick,
Thanks for your reply. What do you teach? I teach chemistry. I didn’t mention anything about bloating or swelling. And I don’t think I have voids behind the tiles. I was pretty careful when applying the thin set to the cbu walls and to the tile itself to be sure I had complete coverage. However, that is a good thought; voids behind the tiles, boy, would that ever be a mold issue!!
I do have access from below, from a crawl space. So far no leaks, but something to watch for. Yes, I was not happy about the attachment of the Redguard to the drain, especially when the insert caused it to peel up. I considered breaking up the floor (not yet tiled) and starting over but I could not bring myself to do it. The method shown in the video right after your post is obviously much better.
I don’t think there are mold on the floor issues. It is uneven, I freehanded the slope, but I don’t think there are puddles there once the water is turned off. I like those plastic guides in the video but was trying to save money. Any dark spots on the floor are just color variations in the tile.
Alvin
Unread 08-01-2019, 07:33 AM   #14
HS345
Tile Contractor
HS345's Avatar
If you didn't build your shower pan with liquid membrane something like this, it's probably leaking. Have you tried doing a flood test?
The name's Greg
Unread 08-01-2019, 10:17 AM   #15
speed51133
That is the "divot" method. just another way to do it. Just because he did not do that does not mean it is leaking....
He can always pop off the tiles and clean the thinset off around the drain and redgard with some fiberglass around the perimeter. yeah, hard to perfectly tie in the old redgard to the new, but overlapping the areas where you scape with new redgard should do it, no?
Double shower from bottom to top! TAL Tile Forum/Advice Board 204 10-09-2016 10:39 AM
mold on bottom corner grout? se7en Cleaning, Restoration and Sealing 7 09-30-2007 10:02 AM
cut tiles at top or bottom of shower JWRYAN Tile Forum/Advice Board 5 09-07-2007 12:13 PM
Corner Mold ziggy96 Tile Forum/Advice Board 1 08-14-2006 11:34 AM
replacing a shower bottom Dray Tile Forum/Advice Board 2 03-29-2006 11:12 PM
