Unread 07-19-2019, 02:56 PM   #16
HS345
Tile Contractor
HS345's Avatar
I'm with Jim, you should never combine copper or brass, and galvanized pipe, it will corrode very fast due to electrolysis.
I'm also with Jim on the Delta tub spout fittings. Recently had a customer ask if I could repair a tub spout in another bathroom. I was building a shower for her, and she purposefully bought a tub/shower faucet set in the hopes that the tub spout could be used to repair her tub spout in the other bathroom. I reluctantly said I would try, but warned her that twisting on an old tub spout could easily result in "plumber's nightmare syndrome". I put it off, and put it off, and finally on the last day I was there, I figured I'd tackle it. Twisted off the old spout, good copper with a long stub out, cut the pipe, soldered on the Delta fitting, screwed on the new tub spout. Easy peezy, about a 15 minute job. Dodged the bullet, for once.
The name's Greg
Unread 07-19-2019, 03:16 PM   #17
Most galvanized is plated prior to cutting the threads, so you have exposed iron there. Plus, the ends often are not plated. In potable water, it will start to rust fairly quickly. In a tub spout, because it doesn't hold water, what little it rusts while drying out often will flush out fairly quickly, but it's not uncommon to eventually end up with a rust stain beneath it in the tub...not nice, and totally avoidable! Those pipe and fittings are good for rough-ins, but replace with brass or copper for the final.
Unread 07-19-2019, 04:57 PM   #18
Just In Tile LLC
Just In Tile LLC's Avatar
Good to know, I considered buying a manual pipe threader for nipples of in-between sizes but copper and male thread sweat fittings were quicker and easier.
Justin
Just In Tile LLC is online now   Reply With Quote
Unread 07-19-2019, 05:35 PM   #19
wwhitney
Originally Posted by Justin
Not sure Wayne, I've never seen a non-PEX drop ear.
Oh, OK. Drop ears come in PEX x FIP, copper x FIP, and copper x copper, maybe other combinations. "Drop ear" just refers to the location of the mounting holes. You can also get a "high ear" elbow in at least PEX x FIP or copper x FIP; the ears are on the face of the FIP side.
Cheers, Wayne
Wayne
wwhitney is online now   Reply With Quote
Unread 07-19-2019, 08:28 PM   #20
Just In Tile LLC
Come to think of it Wayne, I've seen the copper ones a lot on tearouts, maybe I should of said I've never used any other ones. I love PEX and use it almost exclusively.
Justin
Unread 07-25-2019, 08:18 AM   #21
speed51133
I prefer brass to copper
Unread 08-02-2019, 12:38 PM   #22
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Wow. I forgot all about this thread. Here's my current fix.
Used dry 2x4 for the cross piece. Would prefer to use a 2x6 or wider but I didn't have any that were dry. I used a sweat drop ear , with a 6 inch piece of copper soldered, with a pex connector. I also soldered a strap to the piece of copper. This thing shouldn't move.
Oh, and that piece of galvanized pipe is only there to level the angle and for a pressure test.
Travis
It's just a clever handle.
Unread 08-02-2019, 04:00 PM   #23
Just In Tile LLC
Looking good, I like your screw choice...mix and match. I have a loose screw bin in my trailer that I actively use, I like thinking about a guy down the road having to switch bits 3 times to remove my stuff
Justin
Unread 08-02-2019, 09:56 PM   #24
Justin!
Unread 08-03-2019, 09:29 PM   #25
smifwal
. I like thinking about a guy down the road having to switch bits 3 times to remove my stuff
now what did that guy ever do to you? I have run into that shit where I don't happen to have said dumb shit bit. In the Marine corps we would call you a blue falcon
Unread 08-04-2019, 12:21 PM   #26
Just In Tile LLC
HAHA! I use torx screws alot, but when it comes to removing old work and finding the mix and match combo I can't help but pass the same frustration down 30-50 years. Sorta of like passing the torch
Justin
Unread 08-04-2019, 12:36 PM   #27
Like I mentioned in post 2, my plumber says not to use Pex between the valve and shower head, he says the fittings reduce the flow too much. Are any of you finding this to be true? I'm wondering if my plumber is just being cautious or maybe blowing smoke.
Unread 08-04-2019, 01:02 PM   #28
Maniac979
Maniac979's Avatar
I have three showers. All have the same Kohler valve and Speakman shower head. One shower has pex between the valve and head. I don't find any perceptible difference in the water volume or pressure.
Ed
Maniac979 is offline   Reply With Quote
Unread 08-04-2019, 02:02 PM   #29
Tiger Mountain Tile Inc
Is it just a thing when the tub part of it is in play?
Jim Upton
Curious how the new Delta Cruzer tile saw stacks up against Dewalt? Check out the full review and video on DIYTileGuy
Unread 08-04-2019, 03:09 PM   #30
Just In Tile LLC
I guess it could restrict flow, but most shower heads already do that. After switching out the tub spout drop ear it wasn't a night and day difference, in fact I couldn't tell it was more, but not having shower rise I knew something had changed even if ever so slightly.
Justin
Drop-In Tub Install wolfeda16 Tile Forum/Advice Board 4 12-30-2016 09:25 PM
Obama's ears are growing. lasvegaslenny The Mud Box 11 09-01-2010 07:17 PM
dave m and brian got ur ears on opiethetileman The Mud Box 20 10-29-2009 09:14 PM
Drop in Tub handi Tile Forum/Advice Board 3 06-23-2009 03:30 PM
drop in tub gordonhoward Tile Forum/Advice Board 3 06-29-2004 12:40 AM
