Old 05-28-2019, 04:59 PM   #16
Don Monfils
Pro Carpet
Don Monfils's Avatar
That’s funny you said that Leon. I spoke with a local retired tile guy.
I told him the whole story and when I told him that it was Dal- tile, he said ...
“Well there’s your answer”
Is all their stuff crap?
Don
Don Monfils is offline   Reply With Quote
Old 05-28-2019, 07:38 PM   #17
It's not all crap but it's not all good.
Old 06-06-2019, 10:15 AM   #18
Don Monfils
Pro Carpet
Update...
I have to go back and remove and replace about 30 tiles.
Not looking forward to it , is a undstatement.
What is the most efficient way to cut out the grout around the tile?
Is there any attachment I could use on my multi master?
Also what is the best way to remove the thin-set that will remain on the concrete, once the tiles have been removed.
I replaced a tile or two over the years, but never anything like that
Don
Old 06-06-2019, 05:27 PM   #19
Yo, Don!!!
I like this attachment for a reciprocating saw for grout removal. There's also one for grout lines that are 3/16" or more if you need that.
For mortar removal, what works best and fastest for me is this chisel attachment for a demolition hammer (the SDS max). If you have one, it'll make the work go faster, you just have to slow down when you get to the surrounding tile, as the vibration will loosen or damage them.
For your multi-tool, there's also this attachment, but I've not used it, so I don't know how well it works.
Old 06-08-2019, 04:52 AM   #20
Don Monfils
Pro Carpet
Thanks so much Kevin!
Don
Old 06-08-2019, 11:16 AM   #21
CaliGrown
CaliGrown's Avatar
Variable speed grinder with a vacuum makes it a breeze and keeps things clean. Run your blade on lower rpms and the vacuum keeps up with the dust well.
Christopher Machado 1 (916) 990-1751
You are missed Joey Peres (7/16/95 - 8/31/19). Always a great friend with a good heart and the best helper I could have ever asked for. Your jobs will continue on.
Old 06-08-2019, 07:25 PM   #22
Don Monfils
Pro Carpet
Would you recommend something like this on the grinder?
Don
Old 06-08-2019, 07:56 PM   #23
Depends.
For removing grout? No!
For removing the mortar under the tiles, yes.
Old 06-08-2019, 08:23 PM   #24
Don Monfils
Pro Carpet
I thought he was talking about using a grinder for thin-set removal...
I never thought about a grinder for grout removal.
Don
Old 06-08-2019, 08:45 PM   #25
You could use it for grout removal, (not the attachment you posted, but just a regular diamond blade), but the dust would be awful and you'd be lucky not to inadvertently cut into the edge of a tile.
The demo hammer and chisel sends little pieces flying everywhere, and there is some dust, but nothing like the dust from a cup wheel.
The vac attachment does help, though. But it doesn't get 100% of the dust.
Old 06-09-2019, 09:01 AM   #26
CaliGrown
CaliGrown's Avatar
I agree a regular grinder at 11000+ rpms makes a dust cloud.
If you have a variable speed and put it on the lower settings with a standard masonry blade, it’ll breeze through the grout and help get any stubborn thinset up. Kicks up minimal dust if you can keep up with your shop vac.
Old 07-01-2019, 05:37 PM   #27
Don Monfils
Pro Carpet
I got the tiles replaced...about 40 of them.
Thanks so much for the advise. The grout removal tool worked awesome,
and I picked up a M18 hackzall , that is a great tool.
I had the sds demo hammer and bits.
By the way when I was replacing the tiles I ended up having 23 new tiles that also had slight chips in them out of one and 1/2 boxes .
I have about 15 hours into the repair.
Don
Old 07-02-2019, 09:04 AM   #28
Fast eddie part deux
The 40 tiles that you replaced ... were they the ones with the chipped corners?
Ed
Fast eddie part deux is offline   Reply With Quote
Old 07-02-2019, 04:37 PM   #29
Don Monfils
Pro Carpet
Yes!
Don
Old 07-04-2019, 11:59 AM   #30
tilemanct
Tile & Stone
The M18 Hackzall is a great tool.
CTEF Certified Installer
Quarry Tile mack tharpe Tile Forum/Advice Board 5 06-03-2012 06:57 AM
New at Quarry Tile steveschuh Tile Forum/Advice Board 2 04-19-2012 12:07 PM
quarry tile mike5326 Tile Forum/Advice Board 7 03-13-2010 12:03 AM
3/8 IN Quarry tile? Can I still get it? PizzaPrincess Tile Forum/Advice Board 6 08-11-2005 12:53 PM
Is this quarry tile? Janetlee Tile Forum/Advice Board 4 10-29-2001 10:00 PM
