Unread 06-01-2006, 08:17 PM   #1
scorleo
Mapei Epoxy or Spectralock Epoxy Grout?
Hello - I've been tracking a very impressive thread on Spectralock Epoxy grout from Don, I almost bought it but on the second thought I'd like to do some justice to Mapei's Epoxy grout before the purchase. Does anyone have any view on Mapei's Epoxy grout? I'm looking for comparison on price, functionality, life, quality, ease of use...whatever.
Background: I need to grout 1/16" gap for granite tiles 12"x24", room 1: 320 sq ft and room 2: 300 sq ft, both rooms have different color grout.
Feroz
scorleo is offline   Reply With Quote
Unread 06-01-2006, 09:36 PM   #2
DonB
Hi Feroz,
I didn't even know Mapei made one but if I had a job the size of yours to do, I'd look hard at C-Cure ColorSet Epoxy System 931 or one of the Hydroment epoxies. I have a good friend who does mostly restaurant work and he says the C-Cure is the stuff.
I went with the Spectralock because I didn't feel like driving 50 miles to get the C-Cure and I was doing small areas. Many projects but no floors.The other stuff will be a lot more cost effective for you and although I've never used it, I really can't see how it can be difficult for anyone with a properly functioning brain. My friend says the C-Cure is dirt simple.
Keep us posted on what you learn and how it comes out, okay?
Don
Unread 06-02-2006, 01:28 PM   #3
scorleo
HI Don - Here's the Mapei information, just fyi -->
Kerapoxy®
Premium, Stain-Free, 100%-Solids Epoxy Mortar and Grout
Kerapoxy is a premium-grade, water-cleanable, 100%-solids epoxy mortar and nonsagging grout system for installations where exceptionally high-strength chemical and impact resistance is required. Available in all 30 MAPEI colors for grouting, Kerapoxy allows use of light-colored grout without worries about spaghetti, fruit juice, ketchup or other tough stains. Kerapoxy is excellent for countertops, high-traffic areas, areas needing chemical resistance (bottling plants, etc.) – nearly anywhere a conventional grout might stain or break down. It is less sensitizing than other epoxy mortars and grouts. It also meets or exceeds ANSI A118.3 requirements for chemical-resistant, water-cleanable grouting epoxy, and is authorized by the USDA for incidental food contact.
Thanks for the advice on C-Cure, first I need to find out who carries it around this area. I certainly know the store that carries Mapei, or atleast can get the color that I need. Eitherway I'll let you know what I use and how it goes.
Feroz
Unread 06-04-2006, 08:37 AM   #4
geniescience
I just put Mapei's almond grout in my shower. It is more plasticky than the Chembond grout I got a couple weeks ago, so that is good, since the first grout was too sandy for me.
I cut a large container into two parts. Measure carefully.
I put a large amount in the freezer after mixing, and used it the next day to continue.
This grout didn't pick up grit much. The first epoxy grout I put down did.
David.
"Do a search, find out what you can, and come back with more questions."
"...slower than the average DIYer
geniescience is offline   Reply With Quote
