Unread 02-19-2013, 12:44 PM   #1
RedRightHand
Grout Stain, Grout Paint, Grout Colorant: Product Recommendations Needed
i need to color the grout in my kitchen because the brown grout i put down dried almost white (almond-ish).
i used polybend sanded grout, tobacco brown, with ceramic tiles. i tried scrubbing the grout using sulfamic acid, as per the manufacturer's recommendations, to clean up the "mineral and salt deposits that had risen to to the top". that didn't do much except make the color a little more splotchy.
next i tried a sealer/enhancer that did darken the grout to the color on the bag BUT it was still splotchy after 3 coats in a test area.
other than digging out the grout and doing it again, i think coloring it would be my best option now. can anyone recommend a specific product that they have used with good results, please?!
Red
RedRightHand is offline   Reply With Quote
Unread 02-19-2013, 12:54 PM   #2
java
Hugging Trees Oct. 1st
java's Avatar
I've used both C-Cure and Custom grout paint.
What size grout joint and did you use sanded or unsanded grout?
Edit: I see that you used sanded.
Jason
java is offline   Reply With Quote
Unread 02-19-2013, 01:03 PM   #3
RedRightHand
^i think they're 3/16
do you have any direct links to those products? i'm looking for something to color the existing grout, when i go to the c-cure website i only see grout and additives.
Red
Unread 02-19-2013, 02:13 PM   #4
java
java's Avatar
Grout Stain 997
That's what it's referenced as on the C-cure website.
Jason
grout stain/colorant keck Cleaning, Restoration and Sealing 5 04-08-2008 06:12 AM
AQUA MIX grout colorant pre treatment cleaner needed? MaryAnnKacz Tile Forum/Advice Board 0 04-24-2007 08:47 PM
Grout Stain / Colorant AquaMix vs. Custom MarcusEngley Cleaning, Restoration and Sealing 3 01-03-2006 02:02 PM
Any recommendations on a grout stain? Jason_Butler Professionals' Hangout 7 06-04-2005 03:34 PM
Grout stain and seal product L.A. Kader Cleaning, Restoration and Sealing 3 11-21-2004 03:17 PM
