Unread 01-24-2007, 03:41 PM   #1
hardwood1
Unhappy outdoor grouting with custom
can I grout outside on a covered porch with cheap Custom sanded grout if the temperature is just around or below the minimun 50 degrees? Thank you very much. Any questions about prefinished hardwood products or installations please ask....Mirage...Bellawood....above or below grade, etc.....Also site finishes and sanding techniques with exotic woods like Ipe and the like....
hardwood1 is offline   Reply With Quote
Unread 01-24-2007, 04:49 PM   #2
Hi, Give us a first name, hardwood.
You can grout a 50 degrees, but if it's going to get colder than that at night, I wouldn't do it. The grout will eventually set if it doesn't freeze, but the color will probably be blotchy.
