Unread 08-03-2015, 11:39 PM   #1
bmlant
Advice for thermal break
Hey everyone, brand new to forum, so bear with me. I am doing a bathroom reno, installing a freestanding steam shower, and while I'm at it, I will be tiling to the floor.
So here are the details:
Concrete floor in basement
Small bathroom 5'X7.5'
I already purchased True Heat from orange box store.
After doing some online research, I discovered it might be a good idea to install a thermal break so as not to heat "down" into the concrete.
So I went on weekend to get something to install on top of concrete to be a thermal break, and all I came up with was Natural LVT with seal guard. Not sure if this is a thermal break, or meant to go on top of floor. I have since been scouring the internet looking for ideas recommendations, etc. the Ditra in floor heating looks very easy for the DIYer. Thoughts and comments please.
Brent
bmlant is offline   Reply With Quote
Unread 08-04-2015, 12:00 AM   #2
bmlant
Pictures
Product
Brent
Unread 08-04-2015, 12:03 AM   #3
bmlant
Installation instructions
Brent
Unread 08-04-2015, 01:47 AM   #4
Hello, Brent. Welcome to the forum.
That particular product is made for vinyl floor planks, hence the "LVT" on the label. (I believe that stands for luxury vinyl planks).
Do you have a link to the wire you plan to install? I'm not sure a thermal break is required but maybe we can find one that's appropriate for your heat system.
Unread 08-04-2015, 08:51 AM   #5
bmlant
There was nothing specifically regarding a thermal break with the in floor heating system "True Comfort". I found some info online, that suggested it would be a good idea to put in a thermal break so that the floor heats up quicker, and less power is used heating "into" the floor. So I was only going to do it based on the logic of not throwing money out the window. So, do I need a thermal break, if so what is the best product?
Brent
Unread 08-04-2015, 09:25 AM   #6
Tiger Mountain Tile Inc
Hi Brent and welcome to the forum.
I couldn't find True Heat on Home Depot's website but I'm assuming it's a mat style heat system and not a spool of wire?
edit: Is the product True Comfort? It looks like it also comes in a wire and mat.
The product that you've linked to I fear will cause bonding issues with the thinset as it's basically a paint.
While I was on HD's site I looked for products that would work for a thermal break or insulation. I found cork, Easymat, and this product that I've never heard of before.
I didn't look very closely at these products so you'll need to read the instructions. I would stay away from peel&stick products and there is a version of Easymat that comes in a peel&stick.
But these are the types of products that you would want to look for in your area.
Jim Upton
DIYTileGuy
Unread 08-04-2015, 11:02 PM   #7
Ron
Tile Contractor
I don't know if you can get it but 1/4" Wedi board is ideal for just that.
It has an R-value of 1.1 at that thickness but since its body is a foam product (not a dense material), it provides an excellent thermal break and is easy to install in thin-set mortar.
Ron
Terra Firma Tile
Ron is offline   Reply With Quote
Unread 08-12-2015, 02:11 PM   #8
bmlant
Thanks for the reply, I've been away for a bit. So I didn't see til now. I talked to a tile guy at a specialty time store in the city. He suggested I might be over thinking the thermal beak thing. So to save on floor height and product cost, I will be proceeding without the thermal break.
Brent
thermal break when using RPM mats bxd20 Tile Forum/Advice Board 10 11-25-2013 09:09 AM
Thermal break for slate on slab Skivvt Tile Forum/Advice Board 8 06-05-2013 06:42 AM
Thermal break for under tile heat over slab World LLC Professionals' Hangout 34 04-10-2013 11:15 PM
slab thermal break jwmezzanotte Professionals' Hangout 28 01-11-2012 10:25 AM
Thermal break under heated floors/ SOG gitchi gummi Professionals' Hangout 21 02-10-2010 11:12 PM
