Unread 06-02-2012, 08:35 PM   #1
mack tharpe
Quarry Tile
what is the best way to lay broken quarry tile? I have used thin set then grouted buy I don't get the smooth finish. I would like to know the old school method
Mack
mack tharpe is offline   Reply With Quote
Unread 06-02-2012, 08:39 PM   #2
Dave Taylor
Dave Taylor's Avatar
I moved you on over here to the "advice" forum, Mack.
Probably a better shot at gettin' answers to your question here.
Oh..... and welcome to the forum. :--)
Dave T (DIY'er)
the net.
Unread 06-02-2012, 08:39 PM   #3
Welcome, Mack.
Not sure I understand the question. Are your tiles intentionally broken into little pieces, or are you trying to describe a particular pattern using full tiles?
Unread 06-02-2012, 09:15 PM   #4
mack tharpe
tiles are intentionly broken for randon no pattern. all the old millhouse porches had broken. they used mortar,beater blocks and more mortar for grout I just don't know the process how they got it smooth
Mack
Unread 06-03-2012, 06:28 AM   #5
You set them just like any other tile, using thinset and sanded grout. The biggest problem I see with this is the sharp edges. I would take the time to sand or grind each edge a little. I've actually done a couple small entryways like this. Turned out nice but takes time. Is this on a floor or walls? Wood or slab?
Unread 06-03-2012, 06:57 AM   #6
Davestone
Florida Tile & Stone Man
We call it riprap.Here's a pool deck i stripped the sealer off of,what a niightmare job.Get your floor flat first and use a beating block of wood..
http://Davestonestile.com
New at Quarry Tile steveschuh Tile Forum/Advice Board 2 04-19-2012 12:07 PM
quarry tile mike5326 Tile Forum/Advice Board 7 03-13-2010 12:03 AM
Quarry Tile William Given Cleaning, Restoration and Sealing 2 07-26-2009 03:02 PM
quarry tile to quarry tile woodie Tile Forum/Advice Board 4 02-11-2007 07:37 PM
Quarry tile????? Gabi Cleaning, Restoration and Sealing 3 10-24-2004 08:08 PM
