View Poll Results: What trowel size and shape for Schuter Ditra?
1/4 x 3/16 v-notch 6 7.69%
Ditra trowel by Schluter 55 70.51%
1/4 x 1/4 square notch 18 23.08%
1/4 "U" notch 0 0%
Multiple Choice Poll. Voters: 78. You may not vote on this poll
Unread 10-25-2011, 08:56 AM   #1
Trowel size for Schluter Ditra
Schluter recommends that a 1/4 x 3/16 v-notch trowel be used when installing Ditra uncoupling mat. What is your trowel size preference? Please, everyone participate.
Unread 10-25-2011, 01:37 PM   #2
that trowel is undersized
Unread 10-25-2011, 02:13 PM   #3
Shpedly
Interesting they say 1/4 X 3/16 (6 X 5mm) V notch when the Schluter Ditra trowel is 1/64 X 1/64 (4.5 X 4.5mm) square notch. So if the 1/4 X 3/16 is undersized as Rick said, the Schluter trowel is even smaller? Or does the square notch leave down more thinset than a V notch?
Ed
Shpedly is offline   Reply With Quote
Unread 10-25-2011, 03:20 PM   #4
Levi the Tile Guy
Tile and Stone Contractor
Levi the Tile Guy's Avatar
There is no way the recommend a 1/64" notched trowel.
I use a worn down 1/4"x1/4" and it works great for me.
Levi The Tile Guy
Unread 10-25-2011, 03:25 PM   #5
muskymike
muskymike's Avatar
Ditra trowel but Schluter of course.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 10-25-2011, 03:26 PM   #6
Shpedly
Schluter Ditra trowel model TRL-DIT6 1/64X1/64 square notch.
http://www.schluter.com/7005.aspx Scroll down to bottom of page.
Ed
Unread 10-25-2011, 03:37 PM   #7
Levi the Tile Guy
that is 11/64"x11/64" which is just shy of 3/16" and that is referring to their ditra trowel.
Their Kerdi trowel is smaller at 1/8"x1/8" which is equal to 8/64"
Levi The Tile Guy
Unread 10-25-2011, 03:39 PM   #8
jgleason
jgleason's Avatar
Ed,
That is 11/64ths, not 1/64th.
11/64 is somewhat larger than 1/8 (8/64) and somewhat smaller than 1/4 (16/64).
Comparable I'd say to a worn 1/4" square notch.
Name:  cap001 2011-10-25, 17_35_53.png
Unread 10-25-2011, 03:40 PM   #9
Levi the Tile Guy
Ha Joe I beat you
Levi The Tile Guy
Unread 10-25-2011, 04:03 PM   #10
jgleason
jgleason's Avatar
Yea, you did. (But i included a picture)
Unread 10-25-2011, 04:34 PM   #11
java
Hugging Trees Oct. 1st
java's Avatar
Seasoned 1/4 X 1/4
Jason
java is offline   Reply With Quote
Unread 10-25-2011, 04:39 PM   #12
custombuilt
I used a 1/4 by 1/4 before but found it left some bumps were there was too much thinset. Now that I have a ditra trowel there are no problems.
Jason W.
Superior Construction
Quincy, IL
Unread 10-25-2011, 05:22 PM   #13
I use a ditra trowel but i posted in a thread that schluter recommended the 3/16th by 1/4" trowel and i pmed a mod and said i think this is wrong. Anyways i tried that notch on the last ditra install I did and got a bad bond so i switched to the ditra trowel. You gotta replace those schluter trowels too my kerdi trowel worn down and i started getting bad coverage so i switched to the marshalltown v notch.
Unread 10-25-2011, 05:41 PM   #14
I think it also has a great deal to do with the thirstiness of the substrate.
Unread 10-25-2011, 06:01 PM   #15
tileman2000
New England Tile Man
tileman2000's Avatar
5/16th V-notch, I feel more comfortable with that size.
Michael
Trowel size over ditra George 915 Tile Forum/Advice Board 18 05-24-2009 06:46 PM
trowel size on ditra 13x13 and 2x2 on same floor BlueCanyon Tile Forum/Advice Board 6 10-15-2006 11:13 PM
Right size notched trowel over Ditra Mark from Littleton CO Tile Forum/Advice Board 6 01-08-2006 11:57 AM
trowel size--grout size jflm Tile Forum/Advice Board 1 01-22-2003 05:50 PM
trowel size Mike S Tile Forum/Advice Board 3 05-29-2002 09:17 PM
