Unread 10-12-2011, 06:09 AM   #1
m20j
To Seal or Not To Seal My Shower
Hello Tile Experts,
I recently bought a home that has a beautiful walk in tile shower that was installed approximately three years ago. I have no idea who installed it and if it was ever sealed. This will be the primary shower used in the home so I want to do everything possible to maintain its current beauty.
My question is should I seal the grout and/or tile on the walls and floor to be safe? I'm such a tile novice that I'm not even sure what material the tile is made of. I'm including two pictures with hopes that you can help identify the type of tile I have installed so I can proceed with proper maintenance. I've purchased a sealer from Home Depot but have not applied it yet until I receive some advice from this forum. The product is from Tile Guard and it is labelled Penetrating Sealer (stone) for Marble, Granite, Travertine and Slate. It says it is for stone, grout and unglazed tile.
Any help is greatly appreciated!!
m20j is offline   Reply With Quote
Unread 10-12-2011, 07:11 AM   #2
Davestone
Florida Tile & Stone Man
I would take that back and get their Miracle 511,clean the shower good and apply it.I am not a big fan of sealing a shower to prevent staining but with stone i would.
http://Davestonestile.com
Unread 11-02-2011, 07:51 PM   #3
proedwards
proedwards's Avatar
yes, i would seal it
Ryan Edwards
proedwards is offline   Reply With Quote
Unread 11-02-2011, 08:41 PM   #4
CarpenterLearningTile
Mike , I don't know if these were partial or impartial tests.
http://www.tilecleaning.org/grout-se...-procedure.htm
Robert
CarpenterLearningTile is offline   Reply With Quote
Unread 11-02-2011, 10:23 PM   #5
Toddman
Independent Tile Contractor
Toddman's Avatar
Welcome Mike. One thing I would definitely do is, squeegee the walls after each use so it dries out faster.
Todd
Good work is not cheap, and cheap work is not good.
http://www.toddthetileguy.com
Toddman is offline   Reply With Quote
How long to dry grou before seal, and seal before water jimmy0x52 Tile Forum/Advice Board 6 10-28-2012 11:40 AM
Dal Keystone Mosaics - To Seal or Not To Seal hennesse Cleaning, Restoration and Sealing 3 09-01-2010 02:31 PM
511 Seal & Enhance or Aquamix enrich and seal titan7 Cleaning, Restoration and Sealing 7 06-10-2008 12:56 AM
Grout in pores of ceramic tile - To seal or not to seal? sohcrates Tile Forum/Advice Board 3 04-27-2008 02:09 PM
to seal or not to seal a new shower stall Diablo Tile Forum/Advice Board 19 02-12-2004 09:48 PM
