Unread 06-17-2010, 12:34 PM   #1
claycat6699
Handmade tile maker
safe clay body for making outdoor tiles
Hi, I am new here too and am hoping a job that has just come my way will
be settled. Soon.
In the meantime, I have been given the happy challenge of matching an old
outdoor tile. Ok we all know that matching tile glaze colors is so much fun but when they have been up and out there in NY we are a bit worried.
FIRST and most important..the clay body as I will be making these puppies
by hand from start to finish..it's the matching glaze and the clay body that has me in a bit of a tizzy. I normally only use low-fire to mid-range clay so I really need to feel confident that the clay body is secure.
Stoneware, yeah, right, but is there a company that makes really honest to goodness, we will stand by our product, outdoor stoneware, freeze proof(NY remember ooohhh burrr) and
SHOULD I RECOMMEND TO HAVE IT SEALED?
Ok that's my delemma.
Anyone out there that can help?
I hope I have this in the right place..I make tiles not clever computer stuff.
(next life_
thanks so very much for any and all help.
yours in clay,
Catclay
Cat
claycat6699 is offline   Reply With Quote
Unread 06-17-2010, 01:02 PM   #2
Welcome, Cat.
Not sure I understand just what your primary questions is in there, but for sure it wasn't intended to be in that other Visitor's thread, so I made you a thread of your own here.
I'm sure someone will come along and recognize your dilemma.
Unread 06-17-2010, 01:05 PM   #3
Outdoor tile for a cold climate such as yours should be porcelain. fired much hotter than I think you are used to. Porcelain tiles have a very low water absorbancy (less than 1/2% if memory serves), so they won't absorb water and won't need sealing.
So, are you looking for the right clay, the right firing temps or someone to do that for you, or what?
Unread 06-17-2010, 01:25 PM   #4
claycat6699
Handmade tile maker
safe clay body 4 out door tiles
Hi Bob thx
for responding so quickly. Shocking!
Ok I will make the the tiles myself as I am a hand made tile maker.
I understand about porcelain but have not really ever worked with
it for tile. Hmmm
I have been told that stoneware would be good but I really don't
think that is freeze proof enough.
I should be getting the sample soon and then I can see what kind
of clay was used. However, I will start looking for glazes that might
match with a porcelain clay body.
Do You fire the bisque at o4 then glaze and fire at the glaze firing?
Thank you so much,
shall I keep you posted on the process? I will probably be learning
stuff others can use.
I am really excited to get the sample and see what the colors actually are.
Ok enough,
yours in clay,
claycat6699
Cat
Unread 06-17-2010, 01:35 PM   #5
Cat, I've already told you more than I really know about the tile-making process. We have some members that make tile, but they are not here on a daily basis. Try some searches on hand made tiles, or firing tiles, or other such terms.
This thread in our Liberry may be of interest.
Are you trying to make a thru body colored tile? I would think that the glaze you choose would not have to match the clay color otherwise.
Unread 06-17-2010, 06:10 PM   #6
A porcelain tile is (as I understand it) extruded or pressed under VERY high pressure with that type of clay, then fired much higher temps than anything you'd normally do. A good porcelain is much harder than stuff you're used to making, has all of the air pockets (generally) out of it, and quite consistent. You might be better off buying porcelain tile, and then firing it with a properly color-matched glaze. Anything else, other than actually making your own porcelain, probably won't hold up well in the freeze/thaw cycles.
Unread 06-17-2010, 06:55 PM   #7
mossypath
mossypath's Avatar
Stoneware clays fired to cone 5 -11 become vitreous and will work just fine . I have peaces out in the yard for years that have held up well . The way the clay is handled in your studio will have a great effect on the absorption rate of your fired tiles . This is something you can test your self with boiling water and a good scale .
There is a lot to know before you start selling and stand by your product. Lots of good books and web sites out there just for potters
I do wish you luck and would to help if I could .
Tammara
mossypath is offline   Reply With Quote
Clay, Tile, Glaze addicts and anyone interested in clay and tiles Ingeborg Tile Forum/Advice Board 37 10-18-2009 09:11 PM
Question on making an outdoor patio table top out of porcelain tile? Schmidty Tile Forum/Advice Board 12 09-02-2009 09:22 AM
outdoor clay paver job charles2 Tile Forum/Advice Board 4 05-02-2009 09:28 AM
Making Bullnose Tiles/Admix mbond Tile Forum/Advice Board 1 09-24-2006 06:51 PM
Breaking installed granite tiles, safe ? sirivr Tile Forum/Advice Board 6 09-23-2005 01:51 PM
