Unread 10-31-2006, 02:07 PM   #1
bgronski
Grouting "V" Board
I just looked at a house last night, and one of the things they would like done is to have the "V" groove grouted in their plank panel floor. They have already tried grouting it with conventional grout. Only to have it crack and chunk out.
Any suggestions on what to use to fill these grooves???
Brian Gronski
Taconite Tile & Home Improvement
bgronski is offline   Reply With Quote
Unread 10-31-2006, 03:40 PM   #2
koihito
A person, like you.
koihito's Avatar
Are you talking about wood?
Nate
www.mikoskiconstruction.com
Unread 10-31-2006, 03:44 PM   #3
Scottish Tile and Stone
Any trowelable wood filler should do the trick. Bad thing is, they might as well just refinish the floors then.
Scott.
www.scottishtileandstone.com
Laticrete hydroban showers
Mud set stone.
Unread 10-31-2006, 04:01 PM   #4
bgronski
They are wood. Old barn boards or reclaimed from something. Everything in the house is reclaimed. They will not be refinishing at all. They look like they were painted barn red at one time. Now they are worn and all rustic looking. The "V" groove is close to a 1/2" deep. So refinishing would do nothing. It needs to be filled, because dog hair and crumbs are collecting where the grout has come loose.
My thought would be sanded caulk. But being that deep it always shrinks and cracks, and would have to be redone after it cures. Another thought was to use Congolium Acrylic grout. Not sure what will work best.
Brian Gronski
Unread 10-31-2006, 04:58 PM   #5
lou432
Tile Man -- Southern New Hampsire
lou432's Avatar
Brian, I`ve done what your describing quite a few times although most were new construction.
When I couldn`t undercut`m I`d take my time &blue tape`m bein careful to make sure the tape is well adhered to the conture of the V ,then force as much caulking in the voids as possible .
Then take a putty knife&clean the xcess spooge off ,then clean it up w/ sponge+water ,take tape off,come back following day + touch up the shrinkage & reasure the customer that its prolly gona need some periodic maintanance & leave them with a new tube of caulking to match .
Louis
White sand+ blue water .
Find the grace in things that you can`t change, and help some body if you can!
"Van Zant"
I`d rather be on my Harley thinking about God than in Church thinking about my Harley .
My Tile Work Pictures
lou432 is offline   Reply With Quote
Unread 10-31-2006, 06:41 PM   #6
koihito
A person, like you.
koihito's Avatar
I think your going to have a high maintenance floor no mater how you address this if you are not refinishing. That said, I might be inclined to try a color match wood putty. I don't believe caulk is not a good flooring solution, it just can't handle the traffic.
Nate
Unread 10-31-2006, 07:18 PM   #7
duneslider
Utah Tile Contractor
Whatever you put in those cracks won't last. Anything hard will get pushed out as the wood expands and contracts. Anything soft won't hold up very long without looking bad. I've been doing wood floors for a long time and you have a rustic floor there that was installed because someone wanted that look. Many people don't get proper explainations when they make these choices. They really just need to keep the floor vacuumed.
Bryan
Bryan
EX Tile Contractor
Positive Tile and Stone
Salt Lake City, Utah
duneslider is offline   Reply With Quote
Unread 10-31-2006, 08:36 PM   #8
skydivr
How about autobody filler. I used to use bondo to fill nail holes when I did a lot of carpentry work and it seemed to hold up better than most wood filler.
You might be able to mix a bit of stain with it to match the color.
skydivr is offline   Reply With Quote
Unread 10-31-2006, 09:56 PM   #9
Mountain Tile
Pashley Tile
ugh, maybe epoxy grout would work?
Chuck
wwwpashleytile.com
Mountain Tile is offline   Reply With Quote
Unread 10-31-2006, 11:47 PM   #10
duneslider
We use colored bondo to fill knot holes and such. Bondo would require sanding after it sets, which would mean a refinish. Still, the expanding and contracting of the wood will crack anything you put in there. If whatever you put in won't crack then the wood will.
Sounds like a better vacuum or a new floor is what they need.
Bryan
Bryan
EX Tile Contractor
Unread 11-01-2006, 12:49 AM   #11
Trask
Oregon Tile Man
Trask's Avatar
Bryan is right as far as my limited expirence is concerned. I have some old fir Flooring that needed fill in places and I tried a number of diff. products. Epoxy is too hard and eventually separates..Bondo seemed to last longer. High performance wood filler did the same. Anything urathane seemed too soft.
I heard of several polyurethane concoctions mixed with sawdust can work if followed by a good finish coating..but never tried. you almost need something like poly-expandable foam that could be filled, sanded and stained/painted. Something like gorilla glue. That'd be fun
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
Unread 11-01-2006, 01:01 AM   #12
jdm
jdm's Avatar
What about using a router and a straightedge to turn the V-grooves into deeper rectangular grooves, and then insetting wood strips? Not cheap or easy, but it might work.
jeff
Go Rutgers!
Unread 11-01-2006, 09:42 AM   #13
Trask
Oregon Tile Man
Trask's Avatar
Jeff, you musta got good grades. That's a good idea.
Trask Bergerson
Astoria, Oregon
Unread 11-01-2006, 09:45 PM   #14
bgronski
I do not think their objective is to hide the groove, but to give the look of a grout line.
Brian Gronski
Unread 11-01-2006, 09:58 PM   #15
koihito
A person, like you.
koihito's Avatar
You could do that with Jeff's idea by using a contrasting wood.
Plus...there's what we want and then there's reality.......
Nate
