Unread 09-15-2006, 10:06 PM   #1
Hamilton
Bucket abuser
Hamilton's Avatar
Tricks of the Trade
I am well aware this is a highly guarded subject by most and feared not
by some. Id like to start off by sharing a little diddy. Today i finished up
the edges on my travertine tub surround ive been working on with bullnosed
edges. Usually i will stop any custom liners i have cut on the saw short
and border them with some kind of straight edge from the field tile. Today
i decided to run my design band right to the edge and bull nose the 1"
top and bottom pieces as well as the 2&7/8" diamonds and diagonal halves.
Luckily i had some knife grade epoxy on my truck and some fiber glass joint
tape. Carefully i fit the pieces one by one onto the wall and taped them
in place with blue tape, next to the existing tile i had set the day before.
After figuring the exact position of the tiles on the wall by taping them
in place one by one i gently removed them, still taped together and headed
for my setup outside. Still taped together i flipped over the liner and laid some
fiberglass joint tape across the backsides of the tiles. I then skim coated
the back with epoxy, to bond them together. I then proceeded to bullnose
the small pieces as one solid band. Ill upload a pic of the liner on the wall
tomorrow.
Share your tricks and others will too
Jack Hamilton
Hamiltontileandstone.com
Unread 09-15-2006, 10:15 PM   #2
duneslider
Utah Tile Contractor
That looks really really good! Since you are sharing, what do you use to do your bullnosing? What is your process? The company I work for doesn't really offer it and we have people ask for it. If we ever have to do it we send it out. I would like to do it though.
Bryan
Bryan
EX Tile Contractor
Positive Tile and Stone
Salt Lake City, Utah
duneslider is offline   Reply With Quote
Unread 09-15-2006, 10:30 PM   #3
Hamilton
Bucket abuser
Hamilton's Avatar
Good question Bryan. Theres alot of different ways to bullnose.
Me,... I use an easy edge router. It fits on my makita grinder. The
easy edge makes the initial profile. For travertine i create the profile
with the easy edge and then sand out imperfections with a block of
wood with a rough grit sand paper stapled to it. I move to a 400 grit
granite dry pad and then go back to another block of wood with
a fine sand paper. This has been working for me to get the honed
finish. sometimes i will finish up with a swipe of sulfamic acid but lately
ive just been using 511 enhance and seal to bring the color out.
With honed stones its easy to shine them up to much. I guess i could
use a lesson here myself Its been working for me so until i get
better advice its the best i can do.
Jack Hamilton
Unread 09-15-2006, 10:42 PM   #4
duneslider
Well it looks really good. I will have to give that a try and see what it looks like. It is similar to what I have tried but yours looks much better. I don't have an easy edge and that might be the difference. I try to do it with a lot of elbow grease. I had to do a bathroom counter top a while back and I spent darn near half a day getting it to look good.
Thanks for the tips,
Bryan
Bryan
EX Tile Contractor
Unread 09-16-2006, 04:42 AM   #5
pitterpat
pitterpat's Avatar
Jack,
Who makes this easy edge attachment? Tks, Pat
Pat Harris
PAMM Enterprises
pitterpat is offline   Reply With Quote
Unread 09-16-2006, 05:23 AM   #6
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Nice Job Jack.(and a great tip!!)
Felker makes a Bullnosing diamond blade folks. It will give the same profile rough in that jacks getting with his grinder. (another reason to own more than 1 saw) Keep a profiling blade on 1 of your saws and leave it set up in the garage at home. rarely you may want to bring it to the job site but a little planning and forthought and you can just bring home the pieces you will need profiled and polished.
Set up a carpeted board to clamp your tile to along a workbench edge so that you can sand & polish several feet at a time after rough in.
Remember, travertine is a soft stone and pretty easy to profile as is slate and marble.............granite on the other hand takes a bit of doing(ok more than a bit)
I will profile some stone but send out granite!!
Unread 09-16-2006, 07:08 AM   #7
Dan Kramer
Registered Tile/Stone User
Dan Kramer's Avatar
Wow Jack! That is insane looking.
Dan Kramer is offline   Reply With Quote
Unread 09-16-2006, 11:40 AM   #8
Nice edge Jack. I'm good at stopping the liner short and slapping up a piece of field tile too. That looks much better though.
On granite and hard marble I like using the 5 inch grinding wheels to get the majority of the bullnosing done. I have a long piece of Corian that I use to line up 7 or 8 at one time. I follow up with stick on sandpaper of 4 grits on polished marble, maybe 1 or 2 grits for honed. Of course I use the diamond pads for granite.
Unread 09-16-2006, 03:27 PM   #9
Mountain Tile
Pashley Tile
Excellent work jack, I always say it's details like that, that really make a job
Chuck
wwwpashleytile.com
Mountain Tile is offline   Reply With Quote
Unread 09-16-2006, 03:34 PM   #10
Hamilton
Bucket abuser
Hamilton's Avatar
Here is the liner installed, I know you guys got some good tricks too
so lets hear em eh?
Jack Hamilton
Unread 09-16-2006, 03:37 PM   #11
That's just sharp as hell, Jack.
Unread 09-16-2006, 03:52 PM   #12
Hamilton
Bucket abuser
Hamilton's Avatar
Thanks CX Pat im not sure who the maker of the Easyedge is
I bought this one at Dal tile for about $230. Heres a visual......
Jack Hamilton
Unread 09-16-2006, 04:14 PM   #13
Mountain Tile
Pashley Tile
a couple of times my old boss and myself, we would run the marble through the wet saw with a profile wheel on it. then we would make a jig a piece of plywood with a strip of 1x2 along the back edge, then lay the marble on the jig and hone it down together with a grinder and polishing wheels
Chuck
wwwpashleytile.com
Unread 09-16-2006, 08:00 PM   #14
Jack, I guess I've been living inna cave, ain't never seen one of those. Easyedge, I'll havta remember that.
Does it take just one pass to get it bullnosed or several?
Unread 09-16-2006, 08:06 PM   #15
Hamilton
Bucket abuser
Hamilton's Avatar
Several passes, but it seems to go quick. Check with Dal, my local Dal store
carries them. They even have easy edge wheels that make Ogee on
a 1/2" thick tile. I havent tried one. Seems like it would be hard to polish
out that small of an ogee.
Jack Hamilton
