Unread 09-14-2006, 06:57 PM   #1
phobbs
The task ahead of me
Hello my fellow Craftsmen and women,just when you think you've seen all, done all, there comes along the one that you say "yeah great,it will be beautiful". Now you have to figure out how the heck am I going to do this.
The task ahead of me is as follows 16"x16" x3/8"Jerusalum limestone on a 45 in a 36" pattern (4 tiles together ) with 5/8x5/8 Rossa Verona mosaic inlayed around the the 36"grid this is both walls and floor . Floor of course no problem got it installed almost. But the walls now are a different story. Bring it on I'm all ears
Peter
"It was a woman that drove me too drink, and I haven't found her to thank her yet" W.C Fields.
phobbs is offline   Reply With Quote
Unread 09-14-2006, 09:54 PM   #2
bgronski
Can you post a picture of the flooring that you have done? That way I can see how you layed it out and give you my opinion from there.
Brian Gronski
Taconite Tile & Home Improvement
bgronski is offline   Reply With Quote
Unread 09-14-2006, 10:06 PM   #3
If I understand what you're doing, Peter, install the big stones first, little stones later.
I'd rip some nice, straight 1x2s to screw to the walls as vee formation ledger boards to support the four diagonal tiles (yeah, I know the non-sag stuff works, but not for me) in each section. Let'em set up, take off the boards and fill in the spaces with them little bitty tiles.
Make sure you order you some Tilespikes first.
Unread 09-14-2006, 10:08 PM   #4
Trask
Oregon Tile Man
Trask's Avatar
PREFAB_TILT-UP PANEL
Kidding, I'd block out for the lines of mosaic with actual tiles (your 5/8" Rosa) that way you can put one mosaic tile on each corner of the Jeruselum like a spacer. Or use pieces of wood blocks Like 3/4" x3/4" or whatever works for representing the 5/8" plus grout joint on top and bottom.
Don't forget a case of tape
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
Unread 09-14-2006, 10:21 PM   #5
T_Hulse
Tile Contractor
T_Hulse's Avatar
Are the mosaics 1 row only around the 4 big tile?
Tom Hulse
Visit my web site here
Unread 09-14-2006, 10:28 PM   #6
Trask
Oregon Tile Man
Trask's Avatar
I think it's like the lattice type pattern.
Trask Bergerson
Astoria, Oregon
Unread 09-14-2006, 10:34 PM   #7
Hamilton
Bucket abuser
Hamilton's Avatar
I would do it similar to CX's suggestion but rather use scrap stone
cut to the size of the mosaic to be inserted. Using scraps in smaller
doses will let you clean up the majority thinset along the edges
of the 16's while the pookie is fresh. Let the big tiles set up and insert
the bitty ones later.
Jack Hamilton
Hamiltontileandstone.com
Unread 09-14-2006, 10:39 PM   #8
Trask
Oregon Tile Man
Trask's Avatar
I meant using the actual mosaic plus a spacer Jack
Given that it's on a 45.. I think CX is on the right path with the wood.
Trask Bergerson
Astoria, Oregon
Unread 09-14-2006, 11:02 PM   #9
Giovanni Lagana
I always block out the inlay with a wood or stone rip and continue on with the installation of the larger tiles. If you go this route I would suggest allowing for a shim spacer on one side of your spacing rip to avoid your large tiles from binding the rip spacer between them possibly chipping edges when you go to remove them.
Giovanni Lagana is offline   Reply With Quote
Unread 09-15-2006, 04:40 PM   #10
Scottish Tile and Stone
Def. I would do it like CX is a sayin.
Scott.
www.scottishtileandstone.com
Laticrete hydroban showers
Mud set stone.
Unread 09-15-2006, 08:08 PM   #11
T_Hulse
Tile Contractor
T_Hulse's Avatar
I do it like Giovanni does. We cut the tile or stone spacers about 1/16" short & use the sharp wedgies so they don't pinch on the way out.
You're also gonna have to build up the area under the smaller tile after the big tile are set to get them flush. I like to use Nobleseal with thinset under it for that.
Tom Hulse
Unread 09-15-2006, 08:13 PM   #12
JTG
JTG's Avatar
Have you set Jerusalum stone before? It can be a real bear. Make sure that you wipe it often as you go changing the water at least twice a day in you clean up bucket. I would also seal it prior to grouting.
Good Luck
JTG
Jerry
Santa Seattle
Ballard
Unread 09-16-2006, 12:15 AM   #13
Trask
Oregon Tile Man
Trask's Avatar
Tom I use Noble for that too.
Trask Bergerson
Astoria, Oregon
Unread 09-16-2006, 12:37 AM   #14
Giovanni Lagana
For building up thinner material I will mix a bit of pure cement with the thinset so its slightly putty like and lightly tap them flush with a float strip.
Unread 09-16-2006, 09:07 AM   #15
I like mixing a little portland cement in my thinset too for something like this, it works well. Here's an entryway we did back in June with 1 inch mosics and 16x16 tumbled stone.
