Unread 02-28-2005, 03:30 PM   #1
tcolucci
Question Better Bench Installation
Is there any advantage to installing a Better Bench before the shower wall tiles are installed? I know it would mean drilling through the tiles but it would also save us time on cutting tiles to fit around it. We have decided to put one in our new shower and will be installing a granite slab piece as the top of the bench.
Teresa
tcolucci is offline   Reply With Quote
Unread 02-28-2005, 04:04 PM   #2
iloveeva
I just finished doing exactly that. I installed the small version of the Better Bench corner seat in the shower area. I installed it before tiling. My thought was that in addition to the 4 bolts holding it in place, the tiles underneath would give some support and lock it in place. I tiled the bottom and front with porcelain tiles and used a piece of granite for the top (to match the granite for the vanity). I also used stainless steel lag bolts instead of the supplied bolts....maybe overkill, but this will eliminate the possibility of rusting out since the bolts will be wet. By the way, I am an amature, not a professional, so take my comments with a grain of salt.
-Richard
iloveeva is offline   Reply With Quote
Unread 02-28-2005, 04:06 PM   #3
NCTILEMAN
Theresa, that bench should be installed before the tile goes on. The main reason is for support, you need to get that bench back against the studs or it won`t be strong enough. Gary
NCTILEMAN is offline   Reply With Quote
Unread 02-28-2005, 07:35 PM   #4
pfeener
At the risk of jumping into this thread...how do you install a Better Bench in a Kerdi shower? Do you bolt it on through the Kerdi or do you put it on first and then Kerdi over it?
Paul
pfeener is offline   Reply With Quote
Unread 02-28-2005, 07:36 PM   #5
Derek & Jacqui
Send a message via MSN to Derek & Jacqui
Also before screwing to the wall fill holes in wall with silicone and along the two back sides of the bench.
DEREK & JACQUI
NULLI SECONDUS
IMPOSSIBLE DONE IMMEDIATELY, MIRACLES TAKE A LITTLE LONGER
Derek & Jacqui is offline   Reply With Quote
Unread 02-28-2005, 10:49 PM   #6
JJC
Tile Contractor
Kerdi the walls,then tile up to the location of the bench. Bolt the bench onto the wall. The bench is resting on the top row of tile. Pack it with mud. The next day I apply Kerdi over the bench and flash to the wall. It's waterproof!
Jim Carlin
Regional Director NTCA
JJ Carlin Tile Installations
Freeport, ME
JJC is offline   Reply With Quote
Unread 02-28-2005, 11:30 PM   #7
sailfishoney
Teresa
i build my shower benches with cinder blocks and mud it with thin set , you dont need to drill any holes in your tile works great.
sailfishoney is offline   Reply With Quote
Unread 03-01-2005, 09:32 AM   #8
tcolucci
Spoke to the techies at Innovis yesterday and will be installing the bench directly to the hardibacker per their instructions. Although I like the monument benches, I think this is the best answer to our somewhat small shower.
Thanks for all your inputs!
Teresa
Unread 03-01-2005, 08:11 PM   #9
Hi Teresa,
I agree that installing the Better Bench is best done before tiling, but the bench can be installed as a retro-fit. I only want to make that clear for others who might come along and read this thread down the road.
