Unread 10-25-2020, 05:30 PM   #1
jamfalcon
1" Hexagon Trowl Size?
Greetings!
I am moving right along with our bathroom remodel but have hit a question where I have been unable to find consistent guidance.
The floor I am installing will be 1" hexagon tiles, 1/4 inch thick with 1/8 inch grout joints. I have been unable to find consensus on an appropriate trowel to use for these tiles, between a 3/16th V-notch, and 1/4 square trowel.
I am looking to avoid squeeze out as much as possible to avoid any needless cleanup and misery, however, I worry that the 3/16 notch may not provide adequate coverage.
Your input is greatly appreciated. Many thanks!
Josh
jamfalcon is offline   Reply With Quote
Unread 10-25-2020, 05:41 PM   #2
I usually use a 3/16 V notch with 1 inch hex.
Unread 10-26-2020, 12:21 AM   #3
Welcome to the forum, Josh.
I agree with Davy. If you use that 1/4” square-notch, the mortar will be oozing out of the joints way too much.
Have you had a chance to properly prepare the substrate so that you’re installing over a nice, flat surface?
Unread 10-26-2020, 06:11 PM   #4
jamfalcon
Thank you both.
The substrate is level save for the shower pitch. Everything is waterproofed and ready for tile... was just questioning the amount of mortar to use. Thanks again!
Josh
Unread 10-26-2020, 06:29 PM   #5
One of the mistakes I see is that people allow the mortar to dry a little bit on the trowel, particularly on the teeth. As this happens, the notch will get more and more shallow, resulting in less coverage.
So I would spread some, then clean the trowel off completely, making sure the notches are clean to get the best coverage.
Trowel Size for Hexagon Tiles steamedhomer Tile Forum/Advice Board 9 10-24-2019 06:09 AM
1" Hexagon Flooring bugme Tile Forum/Advice Board 14 09-22-2010 10:53 PM
1" Hexagon Tiles "Re" Grout? jennat Tile Forum/Advice Board 1 06-30-2007 08:54 PM
Trowl Size diverdown2000 Tile Forum/Advice Board 3 05-14-2005 10:13 AM
Easy trowl size question metzler000 Tile Forum/Advice Board 1 07-07-2004 09:41 AM
