Unread 10-16-2020, 10:41 AM   #1
barnyardie
Slope
Tub to shower conversion on mid 70’s slab -- 1st timer on this kind of project, but with some tiling experience.
I plan to have a ¼” per foot slope using pitch sticks in building the pre-slope. After membrane, if I use pitch sticks again for the deck mud, the final slope will be ½” per foot. Is this correct, or over-slope?
Richard
barnyardie is offline   Reply With Quote
Unread 10-16-2020, 10:55 AM   #2
Lazarus
Lazarus's Avatar
Overslope. quarter to three eights is optimal. Half will certainly drain, but you don't want to build a water park ski slope, eh?
Laz...
Unread 10-16-2020, 11:21 AM   #3
barnyardie
Got it - thanks.
So utilize straight parallel sticks for the deck mud? I understand sticks, sloped or not, can be a useful guide for a newbie. or not?
Richard
Unread 10-16-2020, 12:44 PM   #4
Lazarus
Lazarus's Avatar
Another option is to use a surface-bonded membrane. In that way, there is only ONE mudbed to deal with and no rubber membrane needed. Look into "Kerdi Showers" on www.Schluter.com
Here is a video of the single mud bed install over plywood. If you have a slab, just ignore the tarpaper and wire lathe shown. https://www.youtube.com/watch?v=5fazbIqsw8E
Finally, here is a good video of setting the Schluter/Kerdi drain. First ten minutes or so. https://www.youtube.com/watch?v=Cbd89xV0OpU
Laz...
Unread 10-16-2020, 08:40 PM   #5
The top mudbed is equal thickness, and just parallels the sloped one below.
A surface bonded waterproofing is, IMHO, a better shower where the entire enclosure is then waterproof rather than most of it being just water resistant.
Properly mixed deck mud is like wet beach sand, and is quite formable. Set a perimeter height, then pack a rim, fill in the middle and pack, then screed it by using the exterior rim you made and the drain, and you're done. It carves fairly easily, and you can throw some down, pack it in, and fill in a depression fairly easily, or scrape off a high spot.
Unread 10-17-2020, 07:27 AM   #6
I would recommend you go with a 3/8" slope, unless you plan to use pebbles on the floor, in which case you'll want to bump that up to 1/2".
If you're using a conventional liner and clamping drain, then you can make your pre-slope 1/4" or more, then set your top mud bed at 3/8-1/2". If you're using a surface-applied membrane, then just make the one mud bed 3/8-1/2".
Either way you go, there's a number of steps involved, and they're all crucial to having a proper working shower. Miss one step or get them out of order and things may not work right. Take a little time to educate yourself in the Liberry before you start, and ask as many questions as you want before you jump in, and we'll try to make it as easy as we can for you.
Drop In Bathtub Deck - Slope or No Slope? RWThrun Tile Forum/Advice Board 7 02-19-2019 12:31 PM
No Pre Slope JenniferThayer Tile Forum/Advice Board 6 09-14-2009 11:49 PM
Shower Pre-slope - too much slope? dj Tile Forum/Advice Board 3 05-24-2006 05:50 AM
pre-slope lbullock Tile Forum/Advice Board 29 03-10-2004 01:13 AM
