Unread 09-30-2020, 05:44 PM   #1
InteriorDesigner4U
Custom Tiled Platform Shower
Hello Fellow Tile Enthusiasts,
I am remodeling my bathroom and saw this shower pan. Looks like a platform (instead of a curb)with glass on the outside. Has anybody tried it? Thanks!
Interior Designer
InteriorDesigner4U is offline   Reply With Quote
Unread 09-30-2020, 06:11 PM   #2
InteriorDesigner4U
Wet Room?
Does whole entire room have to be a wet room? (Doesn't look like it.)
Interior Designer
Unread 09-30-2020, 08:21 PM   #3
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
I think you're seeing something that's not there. It's sort of like an M.C. Escher drawing.
Look where the wall meets the "platform" you see. The glass distorts things a bit too, but I see floor tile running under glass to what I presume is slope starting at inside edge of glass or at the edge of differing tile.
I can imagine that glass in front of slope would be a nightmare to keep clean anyway.
Peter
Unread 10-01-2020, 07:16 AM   #4
Could be they used a border tile, or just let the floor tile run under the glass.
If that shower floor was a platform they would have had to install the glass first, especially with the brackets they used. I don't think there's a chance they did that, and how would they have "finished" the ends of the platform that would show through the glass?
Unread 10-01-2020, 06:08 PM   #5
Tile & Stone Guild
King Of Tile
I would think there is a support running from the ceiling to the 90 of the 2 glass panels. The large panel is too big to leave just attached on the wall. That being the case it's doable.
Jeff
Unread 10-01-2020, 09:57 PM   #6
InteriorDesigner4U
Yes! You are right. It is an optical illusion. Upon closer inspection, in the right hand corner of the picture, you can see the floor tile is running under the glass. It is a flat walk-in shower. Curbless.
Interior Designer
Unread 10-01-2020, 10:05 PM   #7
InteriorDesigner4U
Hey! Could my original idea be possible? Could a glass guy laminate the back of the glass to match the color of the tile, and silicone it in place like a fish tank?
Interior Designer
Unread 10-01-2020, 10:14 PM   #8
Probably, but why?
Please check your Private Messages.
Unread 10-02-2020, 07:17 AM   #9
If the shower floor is actually flat then it won't drain well. If it won't drain well there will be a lot standing water. If there is a lot of water it won't dry. If it won't dry it will develop mold and mildew, and rather quickly.
While some designs look fantastic they are impractical.
Bathroom Project - glass block shower and tub platform - many questions rjardo Tile Forum/Advice Board 30 05-05-2016 10:06 PM
Kerdi Shower system on raised platform oswulf Tile Forum/Advice Board 6 05-20-2008 11:10 AM
Using Jacuzzi platform as part of shower seat, waterproofing personalt Tile Forum/Advice Board 5 09-28-2005 04:57 PM
Raised shower platform design Jeremy T Tile Forum/Advice Board 5 01-14-2005 05:52 PM
custom tiled shower has no slope LNaramore Tile Forum/Advice Board 5 04-12-2002 04:10 PM
