Unread 09-07-2020, 06:10 AM   #1
msaccamango
Oh No! Marble Shower Floor is Chipping!
I finished a recent shower floor (6 months) that is chipping? The tiles are made of marble in an octagon shape.
The tile is chipping only under the rain shower head as it leaks at night sometimes.
This leads me think it is the dripping water. BUT why would this chip the tile? The leaking shower head is due to water that sites in the shower head after the valve is turned off.
The pan was set using a mud base and a pan liner. Then a second slope. The tile was also waterproofed…
Would you be so kind to please advise why is this happening. The tile floor sounds solid. Which is why i think it is the drip from the rain shower?
Mario
Mario
msaccamango is offline   Reply With Quote
Unread 09-07-2020, 08:24 AM   #2
Hi Mario, welcome. What did you waterproof it with?
Marble is unpredictable and can deteriorate when used in showers and especially on shower floors. We've seen this many times over the years. One batch will be fine and the next batch will cause problems and is why we usually don't recommend it in showers.
You could probably replace those few tiles and it might fix the problem but it's likely you'll see more. You can live with it or replace the floor if it starts looking too bad.
Unread 09-07-2020, 08:30 AM   #3
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
I can't think of any mechanism by which the shower head could cause this.
More likely it's the flaking of strata within the stone itself Not all marble is created equal...mother nature saw to this.
With marble available now, I'm afraid you often get what you get, and the "fix" is learning to live with it.
Peter
Stone tile in shower chipping away justRUN Tile Forum/Advice Board 7 11-13-2018 06:37 AM
Marble Shower Floor - Mosiac tile floor wet underneath? Charlie Hesson Tile Forum/Advice Board 11 03-23-2014 05:41 PM
chipping out shower stall tiles muskox37 Tile Forum/Advice Board 2 04-24-2012 08:01 PM
First Cut, Marble Chipping Need Help jsb99 Tile Forum/Advice Board 0 07-02-2007 11:11 AM
hollow sounds & chipping on nwely poured shower floor rsahd Tile Forum/Advice Board 16 01-27-2005 06:56 AM
