Unread 04-10-2019, 10:09 AM   #1
shawninvancouver
shawninvancouver's Avatar
Can this be cleaned??
Not sure what this is? mould? stains? etc.. the tile is porous.. it was sealed.. there are no leaks...
its very strange, only on one wall of the shower... tile under the shower head that gets most of the water is fine.. its around 8 -9 years old..
i have tried to dry it out and re seal it.. they keep coming back when wet..
what can i do??
bleach? any ideas??
thanks
- No Tile Pro here...
shawninvancouver is offline   Reply With Quote
Unread 04-10-2019, 12:24 PM   #2
shawninvancouver
any help here???
Unread 04-10-2019, 01:28 PM   #3
claycarson
Commercial Cleaning and Maintenance
Shawn,
Manmade tile or natural stone?
Try 50/50 bleach and water spayed on so it has 10-15 minutes of soaking time.
If that reduces the marks dramatically, then it was mold stains. Pretty common in this setting.
Post afterwards so we can follow up.
Sent from my SM-G920T using Tapatalk
Clay
www.tileboston.com
claycarson is offline   Reply With Quote
Unread 04-10-2019, 01:29 PM   #4
claycarson
By the way, bleach won't hurt stone or grout, we use it all the time
Clay
www.tileboston.com
Unread 04-11-2019, 07:56 AM   #5
shawninvancouver
Yes, natural stone and porous... but can bleach still get in to clean it if the tile was sealed??
Unread 04-11-2019, 02:46 PM   #6
shawninvancouver
Yessss.. natural stone and soaks water in it.. its not ceramic.. but im sure it was sealed when originally done.... willl the bleach get in there to whiten it??
Unread 04-11-2019, 06:36 PM   #7
claycarson
Shawn,
Not sure, worth a try. If it misses some spots, then you'll know.
The most common type of sealer, penetrating sealer Is not a thick topical film, it's absorbed inside the stone. It allows vapor transmission so it may allow bleach to get the mold stains.
Won't cost a lot of time or energy, so no reason not to try .
Clay
www.tileboston.com
Unread 04-12-2019, 02:03 PM   #8
JohnnyPronto
I would test different chemicals, one tile at a time.
John
JohnnyPronto is offline   Reply With Quote
can it be cleaned lati_cz Cleaning, Restoration and Sealing 3 06-23-2018 08:57 AM
Should tile be cleaned before using Flexcolor CQ grout? AnnLM142 Tile Forum/Advice Board 9 02-13-2018 09:23 AM
Re-using cleaned buckets, when not to? Topspin Professionals' Hangout 39 01-04-2012 09:45 PM
Granite Cleaned with 409..Need Help! ebjustin Cleaning, Restoration and Sealing 17 11-27-2005 07:23 PM
Does new grout need to be cleaned before sealer is applied? hi50 Tile Forum/Advice Board 5 04-14-2004 07:43 PM
