Unread 03-20-2019, 10:40 PM   #1
skiroc
sealing stone before grouting
I am barely a DIY'er and managed to install a nice looking backsplash using 2 x 6 natural stone with another DIY'er friend.
I understand that I need to seal the stone before grouting, but my friend tells me I should not get any sealer on the sides of the stone, that the grout won't stick if it has sealer. However, videos I watch of the sealing process shows people spraying or wiping it on and they don't seem concerned about getting sealer on the sides of the tile.
Since the stone has pits and other natural features, spraying the sealer on would be much easier as long as it's ok that sealer gets on the sides.
What's the best practice?
Don
skiroc is offline   Reply With Quote
Unread 03-20-2019, 11:07 PM   #2
Your friend is steering you right. It’s not a good idea to get excess seal on the sides of the tiles. Dampen a clean, while cloth with sealer and neatly fold it flat. Keep the cloth flat and run it over all the tiles. Fastest way I know.
Unread 03-20-2019, 11:27 PM   #3
skiroc
got it, thanks. I assume using a small brush to dab in the pits would help?
Don
Unread 03-21-2019, 06:54 AM   #4
HS345
Tile Contractor
HS345's Avatar
You'll never be able to keep grout from sticking in the unfilled portions of the stone, and I'm not sure you'd want to. If you want to keep grout out of the pits, you'll have to use a grout bag, or a refillable caulking tube. Is this a true unfilled stone, or are the "pits" just shallow impressions. Can you post a picture?
I personally never pre-seal natural stone before grouting.
The name's Greg
Unread 03-21-2019, 11:15 AM   #5
skiroc
here's a few shots
Don
Unread 03-21-2019, 02:59 PM   #6
HS345
Tile Contractor
HS345's Avatar
Okay, standard unfilled travertine. Like I said, I don't think you're going to keep the grout out of those unfilled areas by sealing them. If you want to keep them unfilled, you'll have to use a grout bag, or refillable caulking tube.
The name's Greg
Unread 03-21-2019, 04:26 PM   #7
skiroc
got it, thanks Greg
Don
Unread 03-22-2019, 12:34 AM   #8
Before sealing, I would clean the face of the tile with a damp sponge, and allow it dry completely. Those travertine can have a lot of dust on them, which could affect the sealer.
Unread 03-23-2019, 11:53 AM   #9
That's really good advice to clean, clean, clean the tiles free of dust before sealing.
But there's no possible way I'd leave those holes unfilled if this is a backsplash. Either fill the holes with grout or they will slowly be contaminated with nasties that are impossible to clean.
Unread 04-12-2019, 01:06 PM   #10
JohnnyPronto
Re: Sealing Stone Before Grouting
DIY friends always know best haha. I know it seems like sealing it after grout would mean the grout is "sealed" but not the case here, I would do it very lightly on face of the tiles avoiding excess sealant on the edges
John
JohnnyPronto is offline   Reply With Quote
Grouting stone mosaic after sealing jf2425 Tile Forum/Advice Board 4 01-18-2017 08:32 PM
Sealing Stone Prior to Spectralock Grouting Tile Guy's girl Cleaning, Restoration and Sealing 5 08-04-2014 05:34 AM
Sealing Before and After Grouting rMacTX Cleaning, Restoration and Sealing 13 02-22-2009 04:00 PM
Sealing before grouting rlelak Cleaning, Restoration and Sealing 5 03-16-2007 09:10 AM
sealing before grouting mandodan22 Tile Forum/Advice Board 3 03-03-2006 07:29 PM
