Unread 01-13-2013, 10:01 AM   #1
gueuzeman
"Standard" format tiles manufactured from larger tiles.
Seems most, or at least more and more tiles are made this way. You can tell by loking at the back of the tile. And becauce they are cut from a larger blank, more and more of them are semi-rectified on the edges, as recreating a cushioned edge would be dificult I imagine.
So think of a domed piece of 24" x 24", with this high point in the middle. Now cut it into 4 pieces. You now have 4 pieces of tile that are very much "not flat", but now can be installed in a running bond at 50%. Installing them without lippage in a grid is difficult enough.
Current floor of 12" Stonepeak(made in USA) is this way, no fun. Another that comes to mind is Ilva (made in Argentina), whose 6.5 x 13" tiles are so bowed that 1/8" joints cast shadows on a subway wall application.
Anyone else found this to be the case?
Rant over.
gueuzeman is offline   Reply With Quote
Unread 01-13-2013, 10:05 AM   #2
The current shower we are on are 12x24 tiles made from much larger tiles. The tiles are pool table flat and have nice crisp corners.
Everyone can make nice stuff, everyone can make junk. Still gotta check what you're going to be working with.
Unread 01-13-2013, 10:12 AM   #3
gueuzeman
I agree, and cost isn't always an indicator.
Unread 01-13-2013, 10:37 AM   #4
Eschbach
Tile Contractor-Virginia
I have seen alot of these also.It can be frustrating because of the cut edge.I point it out to customer before setting so they are informed.They seem more upset that they paid good money and cant even get a "whole" tile.Once the tile is set and grouted they dont seem to notice.
www.eschbachrenovations.com
Virginia Installer of Schluter Kerdi and Kerdi Board Waterproof Showers
Excellence is no accident
Eschbach is offline   Reply With Quote
Unread 01-13-2013, 10:56 AM   #5
bc brick john
bc brick john's Avatar
had a job where they where 3x1.5 and was set out in a shower running bond
half lap
well me setting @ 1/16ths using broken off TLS starps
had tile over 1/8th out of square with factory edge??????
same thing split from a 3X3 not a happy bunny
as opening up joints making compensation for the tile
made it look like i was at fault
as i don't like tapered grout joints
John
Senior Lecturer in Brickwork Masonry
Training instructor/Assessor
brick mason & tile setting
www.stonetilegibsons.ca (under construction)
bc brick john is offline   Reply With Quote
Unread 01-13-2013, 09:13 PM   #6
tileguynky
It the way things are going. Manufacturing process is cheaper this way, less tooling and molds. As for "whole" tile, those that are going to be cut down do get a indentation to "create" the edges of the tiles prior to cutting of the tiles. I have seen the tiles after being made and prior to the cutting process. The cutting down process is very neat to watch.
Unread 01-13-2013, 09:37 PM   #7
I see a lot of the plank tiles being made that way from some Italian tile companies.
they are actually flat and pretty nice.
Unread 01-14-2013, 12:28 AM   #8
PetrH
As one of the builders around here is fond of saying: You can't make a silk purse out of a sow's ear.
I too am not a fan of these re-cut tiles, especially when they are not square. Often there is no way to tell from a sample board what you'll end up getting.
Petr
Unread 01-20-2013, 11:52 PM   #9
MyersFlooring
I know exactly what you're talking about, Geueze. I worked at a [big...really big] flooring store a few years ago & nearly every tile that was available as a family used larger format tiles cut to smaller (particularly common: the 13's cut to 6.5s and down to 2s)...then, you have at least 2 sides that are nearly rectified & one side that's beveled. The warp factor isn't nearly as big as the beveled/non-beveled side issue...
This may be a pretty weak suggestion, but if you use the small rubber spacers, they can compress a bit toward the tips & still allow consistent grout lines...also, I use the wedges from the LASH system a lot, both on walls and to help with grout line issues...
Steven
If the Vikings were around today, they would probably be amazed at how much glow-in-the-dark stuff we have, and how we take so much of it for granted.
Jack Handy
MyersFlooring is offline   Reply With Quote
Reduce 12" X 12" ceramic tiles to 9.5" X 9.5" cogman79 Tile Forum/Advice Board 4 01-03-2009 04:23 PM
Preventing Sag/Lippage on Larger Format Tiles ndisgii Tile Forum/Advice Board 28 02-26-2008 05:05 PM
1" Hexagon Tiles "Re" Grout? jennat Tile Forum/Advice Board 1 06-30-2007 08:54 PM
Grouting 3/16" inset tiles/ 1/16" wall tiles Mummy Tile Forum/Advice Board 2 09-10-2006 09:38 AM
Anyone used Sonoma Tile's "Tantrum" crushed glass accent tiles? edbreyer Tile Forum/Advice Board 2 10-20-2004 06:44 AM
