Unread 11-03-2011, 04:03 PM   #16
Redrobster78
Sorry for all the questions but i assume its ok to use with OSB even if the bag of Custom VersaBond Fortified Thin-Set said do not use on OSB?
Are Custom Building Products good or is there something else at a big box store I should use?
Rob
Redrobster78 is offline   Reply With Quote
Unread 11-03-2011, 04:06 PM   #17
CarpenterLearningTile
I would pull up the OSB and replace it with plywood
instead of taking back the thin set.
Robert
CarpenterLearningTile is offline   Reply With Quote
Unread 11-03-2011, 07:46 PM   #18
CBP makes good stuff. Just avoid the $5 a bag stuff
Unread 11-03-2011, 09:35 PM   #19
Hammy
Hammy's Avatar
Send a message via AIM to Hammy
IS it OSB or Advantec ? Big difference...........
Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Professionally Built Mold - Mildew - Moisture Resistant Showers
Using Laticrete & Schluter Products
Click here to Visit us on Face Book
Hammy is offline   Reply With Quote
Unread 11-03-2011, 11:05 PM   #20
Redrobster78
The under side is stamped OSB... So is that ok to proceed with Ditra?
What is Advantec?
Rob
Unread 11-04-2011, 08:19 AM   #21
Welcome, Rob.
Not at all sure why a fella would assume that.
I see lots of talk about trowel sizes but nothing at all about any evaluation of the subfloor structure you have. Perhaps I missed that? Be good to know if your floor even qualifies for a tile installation before you proceed, think I.
You can use the Deflecto calculator in the dark blue bar near the top of the page to get started on that process.
Then if you decide to use Ditra I would find a thinset mortar that does not proscribe use over the subflooring material you have. There is some question about just what some of those manufacturers actually mean by that, but I wouldn't take a chance on guessing incorrectly.
Unread 11-04-2011, 09:20 AM   #22
Redrobster78
Thanks CX. So here are the facts, 2x10 @ 16" OC w/ 3/4" OSB, span 13'. The house is only 12 years old so the structure is pretty solid. I'm tiling an area that use to be tiled that I've already removed down to the subfloor. I've already purchased Ditra XL as I'm trying to be flush with a new 3/4" hardwood floor.
Those are the facts, what I'm looking for guidance now is what modified thin-set can I use between the subfloor (OSB) and the Ditra XL?
Rob
Unread 11-04-2011, 09:54 AM   #23
Redrobster78
I purchased FlexBond, CBP, as the guy at Home Depot said it should be fine! Is this acceptable to use between the Ditra and OSB even if it says not to use on OSB?
Sorry for all the questions, I feel so confused!
Rob
Unread 11-04-2011, 10:32 AM   #24
Well, if your OSB is of the T&G variety, your subflooring meets the minimum standards for Ditra. If you're happy with that, I'm happy with that.
Might be difficult to find a thinset mortar that actually says OSB is a suitable substrate. The thinking from out here where we don't make thinset mortar is that the mortar manufacturers just don't want you to set tile directly to OSB with their mortars. But that's not what their data sheets say. Data sheet says plywood is a suitable substrate and some data sheets specifically say OSB is not a suitable substrate.
I don't set tiles over either one and don't know how well that works, but I don't ever try to bond anything to OSB with wood glue or construction adhesives. Just doesn't seem to work as well as bonding to plywood. And I'm not one of the folks who bash OSB in general; I think it's a good and useful product. I just don't use it where I gotta glue stuff, even though it's used every day where it's gotta be bonded to joist tops with construction adhesive.
Up to you what you use to apply your Ditra to OSB. Schluter thinks it a fine idea. Maybe axe them, eh? 800472-4588.
Or wait for one of the guys who does that kinda installation to tell you that Versabond will be fine, or suggest something that will.
Unread 11-04-2011, 10:58 AM   #25
Redrobster78
CX, I called Custom and they said it is fine to use FlexBond over OSB. The wording in the package relates to using OSB as the substrate to lay tile. Onto directly, since I'm not doing that it should work fine with the Ditra.
BTW, I always like to beef things up so I glued and screwed full length 2x4 to the top and bottom of the joists, since there are wires in the middle. Thus making it a sort of "I" beam, so it should be more then enough now.
Rob
CBU over Ply, then Ditra - should CBU be thinsetted down. AJMac Tile Forum/Advice Board 6 03-22-2011 07:09 PM
Ditra vs CBU ajaake Tile Forum/Advice Board 11 04-18-2007 11:25 AM
Ditra or CBU Gene Boomer Tile Forum/Advice Board 5 02-04-2007 10:12 PM
1/4"cbu under ditra? customceramicsllc Professionals' Hangout 12 04-03-2006 08:50 PM
CBU or Ditra byoung Tile Forum/Advice Board 3 03-24-2006 08:37 AM
