Unread 11-12-2009, 11:29 AM   #1
JDog
Cultured Marble Shower install ?
remodeling a old shower/bath, want to use durock, with durock tile membrane as substrate, installing 3/8" cultured marble sheet, not my choice, I would have tiled, anyhow, calls for 100% silicone? will this bond to the waterproofing membrane? will there be show through? why not liquid nails tub/surround adhesive? I know substrate sound like overkill, but my opinion is theres never enough waterproofing!
cody
JDog is offline   Reply With Quote
Unread 11-12-2009, 11:34 AM   #2
Probably will, considering the membrane was meant to stick tile to with thinset.
I agree with you. Way too much waterproofing!
Unread 11-12-2009, 12:29 PM   #3
JDog
of I was also considering durock, smooth side with 6 mil visquene on studs, can redguard/blue seal be applied to durock, just wondering, was thinking of using usg mold board above 5' on walls.
cody
Unread 11-12-2009, 08:00 PM   #4
scrandall
Scott Crandall
scrandall's Avatar
All the methods mentioned should work. Durock followed by Durock tile membrane will work well and 100% silicone will bond to Durock tile membrane. Although as Bob above mentioned, you got a lot of waterproofing going on here. As much as we would for you to buy Durock tile membrane, you may not need it in this application. Smooth side our or rough side out for Durock, it doesn't matter. I would go with Fiberock above 5 feet--it's good for wet areas and can be painted like Mold Tough.
Good luck with the project. Let me know if you have questions related to our products.
Regards,
Scott Crandall
USG Substrates and Specialty Division
www.usg.com
scrandall is offline   Reply With Quote
Unread 11-13-2009, 12:40 PM   #5
JDog
thanks scott, i'm a usg man, guess its from the million sheets of drywall I hung.
cody
Marble stone tile over Cultured marble slab shower walls Tap2112 Tile Forum/Advice Board 10 11-30-2015 08:42 PM
Shower cultured marble discolored collinsclan Tile Forum/Advice Board 5 07-11-2010 04:35 PM
Help replacing cultured marble shower floor kanoland Tile Forum/Advice Board 2 02-07-2008 03:23 PM
Cultured Marble install Carrie1000 Tile Forum/Advice Board 3 09-03-2006 07:05 AM
Shower cultured marble discolored collinsclan Cleaning, Restoration and Sealing 4 08-08-2005 09:21 PM
