John,
Failing information from your truss manufacturer, the basic deflection response can be calculated if you tell me the following:
a) size of top and bottom chords (you indicate 2x4s)
b) the distance between top of top chord and bottom of bottom chord (you suggest ~12"). Chords are the top & bottom horizontal pieces
c) the species & grade of wood used (e.g. spruce/pine/fir "select", "structural", "no.1", etc., but is usually stamped on the wood at periodic intervals)
d) confirm that the top and bottom chords are not cut, notched, or otherwise altered to receive the web members (the web is the portion between top and bottom chord - in your case a series of diagonal elements)
e) the total span involved (we already know spacing = 24")
If possible a photo or two showing the typical connection detail(s)
Kelvin
