Mike, is there access under the floor? In a crawl space, the best way to beef up the joints is to add a support beam somewhere near mid span. If finished space, a support beam could be incorporated into a closet along one wall. The closet would be as wide as the tiled area, and deep enough to reduce the span to 10 feet. Sistering the joists with 2x6s will also bring the joists up to spec.
The luan and both layers of vinyl have to go. Then you have to install 1/2" CC or better exterior rated plywood, followed by the underlayment of your choice. If the increased height is a concern, then you remove the planks and install 3/4" T&G plywood, and an underlayment.
