Unread 05-09-2022, 02:41 PM   #1
lochrie22
ADA Shower
Doing an ADA shower on new construction. Would like it to be a no step transition. Floor will be 11-7/8" I-joists 16" on center with 3/4 Subfloor. Shower will be a 4x5. What is the best way to set up the framing for this situation?
Chad
lochrie22 is offline   Reply With Quote
Unread 05-09-2022, 05:16 PM   #2
That depends.
Have you chosen a proprietary waterproofing system?
Unread 05-09-2022, 07:43 PM   #3
PC7060
PC7060's Avatar
Frame the floor with 2”x8” recessed a minimum of 2” below the standard framing.
Unread 05-10-2022, 10:13 AM   #4
lochrie22
Was thinking of using Wedi or Rodkat systems. I was going to up the sheeting to 7/8 and cut the flooring out and block the BCI's for the shower pan section
Chad
Unread 05-10-2022, 12:21 PM   #5
Tiger Mountain Tile Inc
If you're going with a foam pan why not just get the Ligno pan or have Rod make you a similar one? Then you can use the Rapid Recess system and have everything flush out.
James Upton
