Unread 05-19-2022, 10:10 AM   #16
Greg, I don't think you'll find either the Laticrete 9235 or the Custom 9240 is recommended as the sole waterproofing layer for exterior decks over occupied space as you're recommending.
Unread 05-19-2022, 01:56 PM   #17
Noble makes a deck material rated for use over occupied space. https://www.noblecompanyonlinestore....rack-isolation
Flashing and connection to drains will be the harder part, but critical to an overall satisfactory job.
Unread 05-21-2022, 04:59 PM   #18
Kyras
Thing is, Composeal Gold IS recommended, but it failed miserably by extreme shrinkage under heat. I wouldn't trust any roll of plastic not to become brittle and shrink on a deck exposed to sun in the south, based on what I have seen in tearing decks out. While I did not install the failed products, there was nothing wrong with the way the were installed, purely a product failure.
http://sweets.construction.com/swts_...70/E219836.pdf
Seems to be conflicting info, the above says 9240 is rated for exterior decks, perhaps it is old? Other Custom info says contact customer service about decks. Hmm.
Greg
Kyras is offline   Reply With Quote
Unread 05-22-2022, 07:38 AM   #19
Kyras
Still puzzled by this. Composeal turned brittle and shrank.
Doesn't look it, but it is over backerboard, which was perfectly fine and well attached. Looked like it was installed correctly.
I would encourage a membrane embedded in plastic paint based on what I have seen. Noble is cool. Not Redguard, it is not tough enough, it tends to shred under foot.
If you keep those drains, it will pose difficulties avoiding a bird bath in the middle of the floor. At least add a center drain, consider trench drains like whatadrain. You want to attach your waterproofing to the drain. You need a Kerdi drain or similar style with the cotton candy on the edges or a plastic bonding flange. I might consider KerdiFix helpful in that attachment, depending on the drain. However you do it, the junction of drain and membrane is critical and must be thought ahead to have a proper drain for your membrane to bond to. I would still tear the wall off and ditch the drains, much more trouble free.
Greg
anything to put over leaking tile balcony dennis hage Tile Forum/Advice Board 6 11-24-2010 07:17 PM
Leaking outside balcony COMPOSERANNIE Tile Forum/Advice Board 5 04-11-2009 11:56 PM
uh oh... balcony Fractal Tile Forum/Advice Board 21 08-13-2007 01:41 PM
leaking tile balcony Stacie Tile Forum/Advice Board 6 01-29-2006 04:18 PM
