02-13-2022, 10:06 AM
#46
Schluter specifies a minimum of a 2"X2" tile over Ditra. Those tiny squares and triangles in that mosaic are significantly less than the minimum, even the rectangles don't look to be the minimum. The grout joints in that mosaic are very narrow, numerous, and run in many different directions. If the mortar is too thick it will squish up into the joints and be a giant pain to clean.
I might be over-thinking it, but I'd want to do all I could to make sure those tiny tiles are well supported while using the minimum amount of mortar under them.
02-13-2022, 10:13 AM
#47
You raise a good point ss. What I do and I assume most people do is trowel on the thinset, then knock it down using the flat side of the trowel so it's flat and even. That minimizes the ooze. I've cheated with the tile size over Ditra a couple times, when a mosaic or trim portion is small tile but most of the floor is not. I don't think it's a problem in terms of support because once it's grouted, it will stay in place, and after all, if a 1/2" tile is surrounded by larger tile, then it's not really possible to step on the small tile without stepping on the larger tiles around it. With unmodified thinset, I find it's less sticky and doesn't hold as well as the top modified thinsets, and so I get better results with a good thinset like Schluter All Set.
Jeff
02-13-2022, 10:33 AM
#48
It's possible.
02-13-2022, 05:48 PM
#49
Fair enough
Jeff
02-14-2022, 07:08 PM
#50
I have a dewalt 24000 wet tile saw and made a few practice cuts. I have used the saw blade on a couple baths and as I cut this glossy tile the cut is causing what looks like chips in the top coat of the tile.
The blade is a dewalt diamond extended xp4763. I dressed the blade with a diamond dressing stone. The blade seem to be cutting right through not much drag. The cut is nice on the side, just chipping the top coat. I do have another new blade just like it should I try it or do you suggest another type of blade to cut through nicer? Would putting masking tape on before the cut help?
You have to get up close to see it but you can feel it.
Harold
02-14-2022, 07:15 PM
#51
That is similar to what I might expect if you are cutting the tile upside down or your blade is spinning backward (i.e. running through the tile saw from the back end, which occasionally is necessary.)
Jeff
02-16-2022, 08:59 PM
#52
I put a new blade on that I had. Same type dewalt xp4763 and it is some better. It is almost not noticeable after rubbing it down with a polishing stone.
I decided to order a zipper blade to see if that does better. Should be here tomorrow.
Harold
02-23-2022, 11:56 PM
#53
That looks beautiful.
Have you thought about adding the same thickness inside border pieces to both short ends of your rectangle marble inlay?
03-11-2022, 07:51 AM
#54
Finally got the tile job finished. Time to add trim back now.
Harold
03-11-2022, 10:08 AM
#55
Looks great, Harold, all that prep and planning really paid off!
03-12-2022, 12:47 AM
#56
Professional Weekend Warrior
Pro-quality work, brother. Doubt you could have paid anyone to do it any better. Faster? Yes, but no better. Well done!
