Cut out the offending stud. Normally 'california corners' are made from 3+ studs, nailed together* as in the diagram below. That means the offending sutd can be cut out with little affect on the structural strength of the column. When cutting out the stud, we cut higher than we know the niche will be, and lower. To keep things solid, we replace the missing stud with internal blocking (if needed) to keep the wood from curling later.
*we add screws for strength and stability
Paul 1
