Unread 12-20-2006, 11:08 PM   #1
dpbj6
How long before you should seal the grout
hey this is brandon again. i just finished my first tile project. Countertop and back splash . the grout is light so how long should i wait to seal it. and what is the best kind of sealer to use on a counter top.
Thanks brandon
dpbj6 is offline   Reply With Quote
Unread 12-20-2006, 11:16 PM   #2
Jaz
Michigan Tile Pro
Jaz's Avatar
Hello again Brandon,
What kind of sealer did you get for the other project? For counters, be sure the sealer is compatable to be used on food preparation surfaces. It'll tell you on the container how long the grout should dry. It'll probably say 2-3 days?
Jaz
Custom TileSetter (retired)
Method & Product suitability consulting
[email protected]
Unread 12-21-2006, 09:13 AM   #3
Welcome, Brandon.
Please post each question only once and only on one forum. It causes confusion and duplication of effort when folks are trying to respond in more than one place. Bookmark your thread so you can always find it again.
I've also combined the two threads on your previous water stain problem elsewhere. I'll move this one to the Sealing and Restoration forum for more exposure to the right people and delete the duplicate.
First question is gonna be what material have you used for the countertop and splash. Makes a lot of difference in the recommendation of sealers and such. Then I'll let the experts respond.
Unread 12-21-2006, 11:30 AM   #4
dpbj6
thanks sorry i posted on advice fourm and the realized it should be on sealing fourm
i used cermiac tile and mapei grout.
Unread 12-21-2006, 05:11 PM   #5
Davestone
Florida Tile & Stone Man
There are a lot of sealers, and a lot of opinions, Brandon, i like Aquamix,Stonetech,Miracle,myself,just look for an impregnating type sealer,and be sure to let it soak in and reapply as you go if it soaks all the way in, and be sure to wipe off the tile,and don't let it dry on the surface.We sell Stonetech sealers here, another good brand,at the TYW store above.
http://Davestonestile.com
Unread 01-03-2007, 07:40 AM   #6
dcousins
how do you know when you have sealed enough?
I sealed my grout twice using a 20 year product from Home Depot (in a green bottle I think by custom products - called Surface Guard Peneting Sealer). I finally used my shower last night and I noticed that after about 8 hours, the wall grout is back to its original color but most of the floor grout is still dark. is this normal?
DC
dcousins is offline   Reply With Quote
Unread 01-03-2007, 09:45 AM   #7
doitright
doitright's Avatar
Hi Deborah
It sounds like you could use more sealer. The pan receives the most amount of water. It's going to take a while for that grout to dry out before you can do another application.
John Koessler
