Unread 11-09-2006, 03:36 PM   #1
mkv15
How long before i seal the grout
I used c-cure non-sand grout. the instruction say to wait 30 days before i seal the grout. do i have to way that long?
also, do i have to seal the tiles if they are glazed porcelain tiles?
thanks,
mkv15 is offline   Reply With Quote
Unread 11-09-2006, 03:51 PM   #2
Mike2
Follow the directions from the sealer mfg. re. wait time. Generally it's 3 days or so after grouting.
And yes, you've got it right. In your case only the grout needs sealing. If you purchase a good quality sealer and wipe the tiles dry after the recommended sealer dwell time (usually 10 to 15 min.) you don't have to worry about getting the sealer onto the tile's surface.
Unread 11-09-2006, 04:09 PM   #3
mkv15
Many thanks to you and other members here for all the advised and suggestions.
this is a great forum....
Unread 11-09-2006, 04:13 PM   #4
Mike2
Nice to have you on-board Mike. Stick around.
