I think it's more likely the bricks and tile under the mortar were already cracked, they simply used them as filler so they'd A) not not have to dispose of them and B) not have to mix as much mortar.
I think I'd first want to know what's holding up the plywood you found. Do you have access to look at the under side of it, Pat?
What is your plan for the hearth; slightly raised above the finished floor or completely level with the finished floor? What will the finished floor be?
