Unread 02-26-2016, 02:02 PM   #1
Matt Davis
2X4 glazed ceramic tile Question
I am putting 2X4 glazed tile with a small glass tile border over kerdi. Can I use sanded Tec powergrout without scratching the tile? Also would a 1/4 X 1/4 X 1/4 notched trowel be an acceptable trowel size for this tile?
Matt
Matt Davis is offline   Reply With Quote
Unread 02-26-2016, 04:00 PM   #2
1- it will most likely scratch, but you can make a test board to be sure.
2- yes it would be my first choice
Unread 02-29-2016, 07:23 AM   #3
Matt Davis
Thanks for the advice. I think I will stick with the unsanded grout. What is the widest grout line recommended for unsanded grout?
Matt
Unread 02-29-2016, 10:36 AM   #4
1/8"
Unread 02-29-2016, 07:36 PM   #5
Matt Davis
Thanks for your help.
Matt
Unread 03-01-2016, 12:15 PM   #6
dhagin
I've never scratched a commercially available tile with sanded grout. Handmade, art tile, or one-off deco's maybe will scratch. Make a test board and see for yourself.
If you can keep all joints to 1/8 or less, then have a bag of nonsanded on hand just in case.
dana
Sealing glazed ceramic tile Maferni13 Cleaning, Restoration and Sealing 4 08-12-2011 09:57 PM
Help with cleaning glazed ceramic tile jkbullitt Cleaning, Restoration and Sealing 1 04-07-2011 05:10 PM
Is my ceramic tile glazed or unglazed? sorka Tile Forum/Advice Board 1 07-10-2006 05:52 PM
12x12 Glazed ceramic Seal question alreed Cleaning, Restoration and Sealing 1 07-06-2005 03:22 PM
Buffing Glazed Ceramic Tile rlbarnes Tile Forum/Advice Board 6 12-08-2001 10:48 PM
