Unread 01-08-2015, 10:00 PM   #1
jontillman
jontillman's Avatar
Balcony tile massacre
OKAY.... So, I need some advice y'all. I have a balcony that will be tiled in about 30 days after the concrete slab cures. The concrete geniuses have seemed to play a practical joke on me, and poured the ENTIRE 600ft2 area with an 1/8" per foot TOWARD the house...In the areas that don't have pitch/slope, it's perfectly level...GREAT! I have spoken with the builder, and having them back on the job site in any capacity is out of the question, including tearing it out. My plan WAS to have them pour 1" lower than grade and give myself the opportunity to use a mud bed, make my own pitch, and adjust the entire balcony structure to drain as necessary. so... now that is not an option due to height restriction at the entry doors... (seeing as how I can't build my bed thinner than 1") I need to do something else.
I am looking into grinding some of it down, but then i will still need to stay low. Has anyone used a product like Plani-patch or Lati-patch to achieve something like this before? what about thin-setting backer boards at different heights and "floating" or feathering mud around them? does anyone know of a floor leveler that can be used for outdoor use that is approved for thermal shock? If so, can I mix it thicker than the manufacturer's recommendations and screed it? This sucks!
ya jus' gon have that on them big jobs!
Jon
jontillman is offline   Reply With Quote
Unread 01-08-2015, 10:21 PM   #2
Is this a balcony or a patio? From your description it sounds more like a patio.
How much space do you have between the ground (current slab notwithstanding) and the threshold?
Unread 01-08-2015, 10:54 PM   #3
Option 1- Get a few estimates to have someone grind the slab down. Give those estimates to the builder.
Option 2- Run !
Unread 01-08-2015, 11:04 PM   #4
jontillman
jontillman's Avatar
yes it is a balcony. I am 16 ft off the ground. the slab is poured into a pan that is constructed if I-beams and metal plating. from the slab at the current height i have 3" to the threshold.. exactly 1 brick thickness
Jon
Unread 01-08-2015, 11:07 PM   #5
Welcome, jontillman. Please put a first name in your permanent signature line for us to use.
I think Paul got the items pretty close, but maybe in the wrong order.
I think you should simply ask the GC how he intends to have the slab properly prepared for the tile installation. If he wants something done that you're willing to contract for, do that. If not, I think you'd make your best money on that job by saying "No, thank you."
Unread 01-08-2015, 11:17 PM   #6
jontillman
jontillman's Avatar
Thanks cx! i really would like to find another solution if possible, or at least entertain the idea of one. the good news is that i have already laid almost 2700 ft2 of tile on this property already, and i have some time to make the builder make a move. if he has to grind it he will, but i was trying to find some other ideas, just because i feel bad for the guy... and i will not be warrantying this portion of the project seeing as how i will be unable to use the Ditra Drain system.... anything out of the box you can think of other than grinding?
Jon
Unread 01-08-2015, 11:49 PM   #7
Originally Posted by Jon
...and i will not be warrantying this portion of the project seeing as how i will be unable to use the Ditra Drain system....
If you tile it you will be warranting it, Jon. 'Specially if the surface is not brought to the proper slope of a minimum of 1/4" per foot away from the building and you know that and you tile it anyway.
You might wanna contact the folks at Laticrete and MAPEI about those products you mentioned and perhaps others.
You intend to waterproof the substrate when it's ready?
What's under the balcony?
Unread 01-09-2015, 07:09 AM   #8
Splinter
Splinter's Avatar
Pay a laborer to slice 600 sqft of brick in half on a wet saw. The materials savings may offset the labor cost a little.
Alex
Unread 01-12-2015, 08:15 PM   #9
jontillman
jontillman's Avatar
okay, here it is... this is what i'm up against
Jon
Unread 01-12-2015, 08:24 PM   #10
jontillman
jontillman's Avatar
I have talked to several other pros who i know do awesome work, and are knowledgeable, extremely skilled, and have more years of experience than myself, and i am getting a half and half answer. there are a some that say that stacking backer board to achieve height and feathering it out to nothing with a product such as lati-patch is acceptable, and that they have done it in the past, and there are some who say absolutely not, grind it or have it ground down. also, the builder has agreed to bring in a crew for the waterproofing, which he will warranty, not me. ?????
Jon
Unread 01-12-2015, 08:35 PM   #11
And how has the GC agreed to provide the necessary slope?
Jon, we have had that same discussion here many, many times and the bottom line is always the same. You are expected to be the knowledgeable professional and if you tile over that deck you are acknowledging that everything under your tile is acceptable. If you should have a leak down the road and end up in a legal action, you can bet your financial statement that you'll be found to be at least partially liable.
Unread 01-12-2015, 09:05 PM   #12
jontillman
jontillman's Avatar
yep.... and that sucks... ok... DECISION MADE.... i will have the builder tear it out or grind it down... also, CX what do you know about Protecto wrap?
Jon
Unread 01-12-2015, 09:10 PM   #13
Very little. I know their anti-fracture membrane and know folks who have used it. About their other products I know nothing at all.
As with most products out there, type protecto into the Advanced Search feature and you'll find some discussion here.
Unread 01-12-2015, 09:17 PM   #14
jontillman
jontillman's Avatar
cool. thanks bubba
Jon
Unread 01-12-2015, 09:56 PM   #15
Especially if you sign some sort of document / waiver claiming the builder is responsible. Then you will have signed a legal document knowing its the wrong thing to do. That doesn't go well for you in court.
Colorado Shootings/Massacre kate42 The Mud Box 108 08-19-2012 09:20 PM
Tile on second floor balcony tileM Tile Forum/Advice Board 7 10-22-2011 10:29 PM
Porcelain tile on an outside balcony TRAVIS (I.T.M.) Professionals' Hangout 8 08-28-2010 10:35 AM
Balcony tile is sloped towards house! peacamp Tile Forum/Advice Board 3 10-02-2007 06:14 AM
leaking tile balcony Stacie Tile Forum/Advice Board 6 01-29-2006 04:18 PM
