Unread 12-27-2014, 09:24 AM   #1
Pat Peterson
Looking for some opinions and options
I have a home project where I am going to install hydronic heating on top of an existing slab. I am planning on using wood floor joists (16" oc) screwed down to the slab and burying the pipe under 2" of mortar. That leaves me with a flooring base that has a combination of wood and concrete. I plan on tiling the floor surface throughout so that the heat penetrates into the house. Do i need a under-layment? What suggestions do you have for adhering the tiles to the surface?
Patrick
Pat Peterson is offline   Reply With Quote
Unread 12-27-2014, 09:52 AM   #2
Welcome, Patrick.
Why would you install wood joists if you plan to encase your hydronics in deck mud?
The best option I see is for you to install your hydronic tubes, fill between them with deck mud (mortar), lay a cleavage membrane and then a minimum of 1 1/4" of reinforced deck mud over that.
If you have access to the TCNA Handbook, that would be method RH117.
Unread 12-27-2014, 10:53 AM   #3
Splinter
Splinter's Avatar
You'd be smart to run over to HeatingHelp.com and ask about proper methods to install tubing over an existing slab... You dont want to waste half your energy heating the dirt below...
Alex
Unread 12-28-2014, 05:34 AM   #4
Pat Peterson
Thanks CX, I will do some digging around for a copy of the TCNA manual. The reason I am adding the wood support is because of height. I need a thermal break between the slab and the floor and so I end up with room for only 1" of concrete over the pipe. This was advice given by another person.
Patrick
Unread 12-28-2014, 09:34 AM   #5
'Fraid I still don't grasp the benefit of wood joists over a concrete SOG, Patrick. How would that provide a thermal break between slab and heating system?
Unread 12-28-2014, 09:44 AM   #6
Splinter
Splinter's Avatar
Im guessing wood joist, plywood subfloor and then mud on top of that. Gonna add a few inches to the floor height with that setup.
Alex
Unread 12-28-2014, 12:02 PM   #7
PC7060
PC7060's Avatar
Pat, I'd recommend 1" or 2" polystyrene panels as a thermal break. 25 PSI panels should work well. Lowes branded panels meet ASTM C578 Type IV (25 psi rating) as does Owens Corning Foamular 250. I'd apply thinset under the panel to ensure all voids are filled. Use tapcon screws the fasten the panels to the slab. You should be able to set the tubing in a mud bed per CX guidance. I'd also take a look at the site Splinter recomended to verfy the thermal break method I described is appropriate for your purposes.
Unread 12-30-2014, 09:06 AM   #8
Pat Peterson
Thanks for all of the info. Before I proceed with the house plans any further I have concluded that it is best to look for a local tile installer. Probably best to get build specifications from two or three in order to get what I need.
Patrick
Opinions, please! CWMCPA Tile Forum/Advice Board 81 10-08-2010 03:33 PM
Can I get some opinions lasvegaslenny The Mud Box 17 05-20-2010 10:55 AM
Some opinions?? John Corley Tile Forum/Advice Board 9 12-20-2004 07:23 AM
Need Opinions Art in Stone Professionals' Hangout 10 12-07-2003 11:57 AM
opinions WilliamL Professionals' Hangout 25 03-21-2003 10:22 PM
