Unread 11-15-2013, 02:01 AM   #16
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
I'll try that too Greg, thanks.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 11-15-2013, 09:47 AM   #17
That is a really great article, and a heck of a plug for our friends at Aqua-mix/Custom Building Products.
http://www.custombuildingproducts.com
Unread 11-16-2013, 09:02 PM   #18
Here are the pictures I forgot to add to post #14- showing packing and roller marks. (look close)
Another interesting thing. We were supposed to receive all the same lot # but we got two different shades of the same tile. One lot had the kiln release marks, the other batch had none.
Will try all the various cleaning techniques on Monday and report back. Sure hope we don't have to rip up tile.
Isaac
Maui, Hawaii
Unread 11-17-2013, 04:25 PM   #19
Floorit
Tile, Stone and Hardwood
Floorit's Avatar
Brian, thanks for posting that article. Wish I had known it in February.
The tile I had a problem with was in almost completely enclosed cardboard with only about a 6"x6" opening on one side.
Isaac, I hope you can clean it up, I know the nano-scrub did nothing for me.
Ray
Germantown Tennessee Tile Stone Hardwood Installation
NWFA Member
Tennessee Installer of Schluter Kerdi Waterproof Showers
Tennessee Installer of Laticrete Hydroban Waterproof Showers
"Life is pretty simple:you do some stuff. Most fails. Some works. You do more of what works. If it works big, others quickly copy it. Then you do something else. The trick is the doing something else." Leonardo Da Vinci
Floorit is offline   Reply With Quote
Unread 11-18-2013, 07:41 AM   #20
MAPEI - Technical Service
Company Representative
I read through the article and wanted to add my insight as well from someone who has worked in a porcelain factory and imported thousands of containers of porcelain from overseas. While kiln wash can definitely be deposited on the front of tiles, usually what is physically happening in transit is that the kiln wash acts like poultice and abrades the surface of the tile only where contact is made with the back of the next tile. Typically this happens on glazed porcelain where the glaze is soft (Visible Abrasion II or III) and the surface is flat. About the only thing that can be done is to use an abrasive cleaner (the Barkeeper's Friend is a good example) and try to even out the gloss across the entire piece. Before tearing out all of the tile, you may even want to try an orbital buffer or consult with a stone refinisher.
On another topic, the roller marks in the photos above occur when the rollers in the kiln get glaze on them. The glaze 'grabs' the tile as it passes over the roller and gives it that characteristic hump. Ironically the kiln wash is specifically added to the back of the tile to prevent this so too much kiln wash can lead to the pattern you see that looks like a grid, too little can lead to roller lines. Manufacturers pull the rollers out of the kiln on a regular schedule and clean the glaze off of them, but if they are not cleaned in time then you get the issue you see there. The challenge with this defect is that you won't see it until you get wash lighting from across the room showing it up.
Holden
http://www.mapei.com/US-EN/
Unread 11-18-2013, 02:30 PM   #21
Dave Gobis
da Man!
Dave Gobis's Avatar
My experience is the issues Dan mentions are the more common complaints.
Unread 11-18-2013, 10:59 PM   #22
dhagin
Thanks for the run down Dan, very interesting... either way, it don't seem like a tile guy should be on the hook for it.
dana
Unread 11-18-2013, 11:11 PM   #23
'Specially not if the manufacturer is actually aware that the defect might not be evident before the tile is installed, Dana. Makes it difficult for a fella to do the right thing, eh?
Unread 11-18-2013, 11:30 PM   #24
Of course all the tile boxes have fine print that say the basically the same thing-
"If you are dumb enough to set it, it's your tile"
Isaac
Maui, Hawaii
Unread 12-02-2013, 07:46 PM   #25
Peerless Tile
Tile Contractor
What ever came of this problem Isaac? Did you get the marks off? If so, with what?
SC Greg
Peerless Tile is offline   Reply With Quote
Unread 12-02-2013, 08:39 PM   #26
MNTileGuy
Central Texas Tile Guy
I've found BKF to be one of the best cleaners for removing garbage like this, or, more commonly the case for me, thinset haze that doesn't want to come off the tile. The stuff's dirt cheap too.
Props again to Tile Joe for recommending that some time back. Has saved me a lot of wailing and gnashing of teeth.
Brad Bressler
Bressler Tile and Stone
www.bresslertile.com
Unread 12-02-2013, 11:41 PM   #27
Tiger Mountain Tile Inc
I don't know what BFK is? Does it stand for something?
Unread 12-03-2013, 01:28 AM   #28
Jim BKF stands for Bar Keeper's Friend.
Thanks for the reminder Greg. We were able to remove it fairly well. But if you look hard enough in certain conditions you can still see it slightly.
Tried all of the pictured items. What worked best was the diamond impregnated pad on my variable speed. (the little grey thing in the center)It was 800 grit. I don't have a link for the exact pad I used but got it from a local cleaning supply company that also has stone restoration supplies. They also sell full size pads for large floor machines that would be helpful if you had to do an entire floor.
Here is a link to company I found when i googled Diamond Impregnated Pads- I don't know anything about this company but their name sounds familiar
http://www.jondon.com/supplies/concr...hing-pads.html
The other chemicals didn't do much for us.
The client gets arrives in a few days. We informed them of the problem, we will see how the final walkthrough goes. They personally selected the tile but we provided it in our quote.
Isaac
Maui, Hawaii
Unread 12-03-2013, 08:27 AM   #29
any pictures of the tile in the light ?
Unread 12-04-2013, 01:57 AM   #30
No but will try to get some and post. May be a few days.
Isaac
Maui, Hawaii
Kiln release Grovertile Professionals' Hangout 53 04-24-2017 06:41 PM
Spectralock On Textured Porcelain - Do I Need A Grout Release? JC-TX Tile Forum/Advice Board 6 10-22-2013 11:03 PM
Furniture marks on porcelain tile RBard48 Cleaning, Restoration and Sealing 2 03-13-2013 01:20 PM
porcelain tiles with drywall mud marks Theresa Cleaning, Restoration and Sealing 2 08-19-2006 10:01 AM
Pencil marks on porcelain tile jeffdeline Tile Forum/Advice Board 2 06-30-2004 07:16 AM
