Unread 08-04-2009, 03:53 PM   #1
TonyY
Durock the shower curb or tile over rubber liner
I'm creating a tiled shower and need some help. I ran a rubber liner across the floor, up the 3 full walls about 8 inches and up and over the 4" curb. I had to overlap the rubber, I used cement and have good solid bond. I nailed the rubber to the 3 full walls about 7 inches up from the floor using galvanized nails then ran durock on the entire wall down to the shower floor stopping with my last screws about 5 inches up.
My question: Do I Durock the curb? I wouldn't think tiling vertical rubber surfaces would hold very well. Any help or other tips for completion would be great, thanks!
In searching, I found some info on using metal lathe over the curb and I think I have it now but should I lathe and morter over the durock walls or just tile them directly
Tony
TonyY is offline   Reply With Quote
Unread 08-04-2009, 04:36 PM   #2
Welcome, Tony. )
Go to the Shower Construction thread in our whirl-famous Liberry and you'll find some good information on that and constructing the rest of your shower pan.
I recommend you read everything in that thread, matter of fact, before you go any farther on the project.
Redgard mortar shower pan that already has rubber liner? lacrebob Tile Forum/Advice Board 2 05-08-2009 08:51 PM
Shower Durock meet PVC Liner and mortar bed light guy Tile Forum/Advice Board 11 02-27-2009 12:37 PM
OK to use Redgard before rubber shower pan liner sdnomad Tile Forum/Advice Board 2 12-14-2007 02:31 PM
Rubber shower curb Rich Turley Tile Forum/Advice Board 0 11-24-2007 10:05 AM
Blue seal (waterproof rubber membrane) over durock, overkill? newbieonhomes Tile Forum/Advice Board 4 07-27-2006 10:49 AM
