Unread 06-30-2008, 04:54 AM   #1
Sterving
Weekend Warrior
Question Toilet flange over tiled surface - to fasten or not?
I am tiling my bathroom. After determining that the existing flange will be sitting too low below finished surface (original tile was sitting on the plywood subfloor), I cut the old one out with the bend piece by accessing it from below. I installed new bend and a coupling. The finished surface will be, naturally, tile.
The question is - do I have to fasten the flange to the floor even if it sits flush and secure? That would require drilling through the tile in 4 places. Can I leave it un-fastened since the toilet will be sitting flat on the floor?
Dmitriy
If you want it done right, you have do it yourself. If you do it wrong, you know who is to blame.
Sterving is offline   Reply With Quote
Unread 06-30-2008, 05:46 AM   #2
Hammy
Hammy's Avatar
I normally DO NOT tile under the flange. In my opinion the flange MUST be fastened to the floor. This secures the the toilet to the structure with out relying on the drain pipe to hold the commode in place. Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Unread 06-30-2008, 09:41 AM   #3
The correct, but not the easiest way, especially after you went to the trouble to raise the flange, is to install it on top of the tile where it is designed to be. It is easier if you notch the tile so you don't have t odrill through them, so that the flange can (and it must, unless maybe it's cast iron and surrounded by cement) be anchored to the floor.
Unread 06-30-2008, 10:29 AM   #4
Sterving
Weekend Warrior
Ok, so the plan is to make tile cut-outs in the areas where fasteners will go to avoid drilling. I don't have the appropriate drill bits, but I do have angle grinder, hand wet saw (for plunge cuts) and nippers. I think that should do it.
Dmitriy
Unread 06-30-2008, 10:42 AM   #5
mozilla
My personal opinion would be to drill slowly (add water as you drill down) through the tile with a carbide bit, use Tapcon screws (concrete substrate) to hold down the flange. If you go this route, make certain that you level your flange using plastic shims. Once level, screw down the flange through the tile and the substrate. Good luck.
Randy
mozilla is offline   Reply With Quote
