Unread 02-01-2020, 01:07 PM   #1
Randmfernandes
Kerdi shower leak
Good day
We installed a DIY kerdi shower. We used kerdi membrane, the polystyrene pan, but built the curb from plywood. We did not cover the plywood with cement board. Only membrane. We took great care installing but still our shower developed a slow leak.
We had kerdi inspect. They said our problem was that we had not used cement backer board. They seemed to think that was the root of the problem.
I have now opened the tiles to see what is going on. It looks like the problem is an area where membrane is not properly bonded.
My question: can I fix this area by filling the gap with thinset and applying kerdi membrane / band or do we really need to rip out the curbs and replace with kerdi curb or apply cement backer board? How significant was this mistake we made. Any advice is appreciated.
Marle
Randmfernandes is offline   Reply With Quote
Unread 02-01-2020, 01:43 PM   #2
Hi Marle, welcome.
First of all, do you have any left over tiles from this installation or can you get more to do the repairs with?
What's behind the Kerdi on the walls?
I'm not a Kerdi expert but I would remove the door and curb, that way the curb can be rebuilt back. Before doing any demo, take measurements so the curb can be built back exactly as it is now, that way the door will fit back.
Get the curb and Kerdi work done and do a flood test before setting any tiles back.
Others will be along to help.
Unread 02-01-2020, 01:54 PM   #3
This isn't looking like it would be an easy repair as removing the tiles damages the kerdi.
As much as I hate to say it, this would qualify as a re-do. The hard part of any shower is the floor area, so the walls are the quicker, easier section to re-do.
When the glass was installed - was the kerdi membrane penetrated with fasteners?
Unread 02-01-2020, 01:58 PM   #4
Dchesky
Based on what I’ve learned about kerdi membrane, it cannot be directly applied to wood. It has to be either gypsum, cement board or some other suitable substrate. That is the problem. So unfortunately you will have to remove the curb entirely and reinstall a kerdi curb or build one with 2 x’s and cover with densglass, cement board or even 1/2” kerdi board. Use the band to waterproof all seams and screws in the curb and inside outside corners before tile.
Dchesky is offline   Reply With Quote
Unread 02-01-2020, 02:05 PM   #5
Randmfernandes
Thanks for reaponses so far. We have green board behind shower walls covered with membrane. We thought we isolated the leak, through testing, to the floor and corner around curb area where i pulled out tiles.
When we installed the shower walls/ door we did penetrate kerdi. We put silicon on the screws. Do you recommend an alternate method?
Marle
Unread 02-01-2020, 02:15 PM   #6
Try to answer any questions we have, it helps us help you. Any left over tiles?
I wouldn't say it's a redo at this point but could end up being that. I think it's worth trying to fix although the time needed might take as long as a redo.
Unread 02-01-2020, 02:29 PM   #7
Randmfernandes
Sorry davy. Missed that one. Yes we have enough for a repair.
Marle
Unread 02-01-2020, 02:36 PM   #8
In that case, I'd try to repair it. I do think you'll have to remove more tiles on the wall in that area and hope the Kerdi isn't damaged in the process.
Unread 02-01-2020, 04:27 PM   #9
makethatkerdistick
To me, the Kerdi seams look awfully loose. Is there air under these areas, or is it an excess of thinset?
Regardless, if you are attempting a repair rather than a redo, I'd probably use Kerdifix to inject into those areas and smear across the seams to achieve a better seal. If you use thinset, you might end up with too much. This will keep wicking moisture. The Kerdi system only works properly if the thinset under the seams is applied thinly and has full coverage. And even then, it needs to dry out between uses. If there is too much wicking going on, then it'll essentially never get dry and keep slowly leaking.
If you have to remove strips of the Kerdi membrane, keep in mind that it will result in the fleece being torn off at least from one side of the membrane, thus making a potential bond to a fresh piece of Kerdi virtually impossible, at least with thinset. I am not sure if the Kerdifix will attach de-fleeced membrane to fresh membrane. It might. If that is a problem for you, you might want to ask Schluter about it.
The green board is also somewhat of a mistake, albeit a smaller one. Its surface is waxier than that of normal drywall, thus potentially diminishing the bond between it and the Kerdi. Regular drywall or cement board are a better choice.
Lastly, if you want absolute peace of mind, this would have to be redone properly, unfortunately. But by all means, give it a shot with the repair.
Wolfgang
Unread 02-01-2020, 06:51 PM   #10
Regarding the screws on the shower door, were any driven into the curb, or just the walls?
Unread 02-01-2020, 06:51 PM   #11
And in what order was the Kerdi installed, floor or walls first?
Unread 02-09-2020, 01:41 PM   #12
I agree with Wolfgang. If it's your shower and you want to try to fix it with as minimal impact as possible I would try the Kerdi fix route. Test it before covering it with tile but keep an eye on it from here on out.
Jim Upton
New DIYTileGuy blog post: Flood testing a shower pan: Why it's done and how to do it
Unread 06-27-2020, 06:10 PM   #13
Randmfernandes
And finally I’m back.... after I started this thread it took considerable courage to take the next step.
I have removed the wooden curbs, Kerdi shower base. I have purchased Kerdi curbs and want to get this project done.
I think I realize that there was too much thinset in the install. Looks like we picked up an air bubble. Additionally we had cut the floor to create a Curbless shower. Then realized our shower doors looked stupidly short so put a curb in. The back and forth left a gap between the curb and the shower tray. I think coupled with movement from wood curb this was a bad combo.
So I’m thinking to build the floor back up to pre Curbless height to get a fully adhered butt between kerdi shower tray and kerdi curb.
Questions: in removing the first few rows of wall mosaic I have significantly punctured the kerdi membrane. Can I put kerdi fix on this and get a decent 2” overlap with kerdi band to get a decent new seal or is this cause for redo?? And if not is kerdi fix vs tho set the right solution here. Even for kerdi band install?
Second I will see if there is any Way possible to fit the geometry and keep my original kerdi band onto curb to bathroom floor intact. You will see I kept the outside curb tiles in place and hope to build the kerdi curb on below it. I am nervous to remove any tile close to my floors. We only have very limited curb/floor tiles left and they are discontinued. Any advice with this piece?
Third: I have seen a lot of debate on if / and how to screw a glass shower wall into kerdi membrane. My screws closest to Corner we thought there was a leak were rusted through. I’m not sure the glass would stand with silicon alone and wall fasteners? What are recommendations on drilling into curb after membrane. We did fill the original holes with silicone. Doesnt look like it helped.
Marle
Unread 06-27-2020, 07:16 PM   #14
The curb catches a lot of water and is usually the first place a shower leaks. After looking at these pictures I'd have to replace the whole shower. You might can do it but It's difficult to patch a Kerdi shower and it not leak. I wouldn't take that risk, myself.
Unread 06-27-2020, 07:41 PM   #15
Welcome, Marle.
I'd hafta side with Davy.
Kerdi Shower Leak or Shower Door Leak? cnap Tile Forum/Advice Board 20 07-15-2019 12:54 PM
Kerdi Shower leak test Fail Amatuer2015 Tile Forum/Advice Board 10 06-16-2015 05:08 PM
Leak in Kerdi shower bed? Richard317 Tile Forum/Advice Board 12 09-10-2008 10:31 PM
Leak testing of Kerdi shower peterd Tile Forum/Advice Board 3 04-28-2005 02:36 AM
Leak Testing a Kerdi Shower? Anthony Tile Forum/Advice Board 7 06-08-2004 02:29 PM
