Unread 10-25-2011, 08:25 PM   #1
robinP
self leveling compound question
I just applied a self leveling compound over my plywood sub floor (product was recommended by a professional tile setter). It was a different brand than the one I had used previously. I just realized that this one called for a primer, which I did not use. I will be using a Ditra membrane over this (applied with modified thinset). My question-have I compromised my tile installation? The area in question is under the washer and dryer so it will not be walked on. If I need to scrape the compound up, I should do it now before it dries completely. What are your thoughts?
Robin
Robin
robinP is offline   Reply With Quote
Unread 10-25-2011, 08:33 PM   #2
Toddman
Independent Tile Contractor
Toddman's Avatar
That primer is what allows it to bond to the plywood. The way some washing machines shake and rumble I'd be worried.
BTW if you're putting Ditra over a cementitious surface, they call for an un-modified thinset, not modified.
Todd
Good work is not cheap, and cheap work is not good.
http://www.toddthetileguy.com
Toddman is offline   Reply With Quote
Unread 10-25-2011, 08:42 PM   #3
robinP
Thanks, Todd. I was afraid of that but hoping the opposite. and you're right about the unmodified over the cementious compound. I had not even considered this so thanks for bringing it to my attention. The rest of the floor is plywood so I should use the modified under the Ditra..correct?
Guess I should go start the scraping. I appreciate the advice!
Robin
Robin
Unread 10-25-2011, 08:43 PM   #4
dbol
dbol's Avatar
You need the primer. It is what bonds the self leveling to the plywood. what brand is it?
doug
dbol is offline   Reply With Quote
Unread 10-25-2011, 08:54 PM   #5
robinP
RS Self Leveling Underlayment. Calls for Levelquick latex primer. This was all the home store had. I'll learn to read the directions. Going to be all night getting this stuff up
Robin
Unread 10-25-2011, 09:00 PM   #6
Toddman
Toddman's Avatar
That's good SLC. My choice. Good luck.
Todd
Unread 10-25-2011, 09:10 PM   #7
robinP
Thanks. My first bathroom project. Done other tiling before but was totally unprepared for the intensity of this job! I'm just an older Mom who has always tackled home improvement projects solo. Determined and dedicated to doing it right. I've realized that I missed my calling. Should have been a contractor instead of a teacher! I absolutely love it (even with all the glitches) but thanks to pros like yourself, I've learned a lot.
Back to scraping
Robin
Unread 10-25-2011, 09:13 PM   #8
Toddman
Toddman's Avatar
Ok Robin, breaks over! J/K We're her for ya anytime.
Todd
Unread 10-25-2011, 09:35 PM   #9
The good part; It should come up easily
Unread 10-26-2011, 10:06 AM   #10
robinP
Is it necessary to use the metal lath over the primer?
Robin
Unread 10-26-2011, 10:15 AM   #11
What does the manufacturer of the SLC say about that, Robin?
This is for your bathroom project?
Unread 10-26-2011, 10:30 AM   #12
robinP
It says to use metal or plastic. The area of concern is under the washer/dryer. Some of the other SLC's don't require a metal screen so was wondering why this product's instructions called for a screen. I'll be using Ditra over the entire bathroom. I am having difficulty getting it up in one small area.. It's definitely bonded..chisel and hammer time, I suppose.
Robin
Unread 10-26-2011, 10:32 AM   #13
Because the manufacturer's product testing engineers overruled the marketing guys and the finance guys listened. Other than that, it's pretty arbitrary...
Unread 10-26-2011, 10:37 AM   #14
robinP
I hear ya!
Robin
Self leveling compound alvarto Tile Forum/Advice Board 6 08-08-2008 04:55 PM
self leveling compound question Jackman Tile Forum/Advice Board 1 09-04-2006 02:58 PM
Leveling Compound, again KitchenSlope Tile Forum/Advice Board 22 07-05-2006 09:47 PM
Self Leveling Compound Briyon Tile Forum/Advice Board 13 11-18-2005 05:30 PM
self leveling compound johnboy Tile Forum/Advice Board 2 01-10-2002 07:14 PM
