Old 06-22-2018, 04:26 PM   #1
msn
pre-sealing thassos mosaic tile
Hello,
Can you advise me on how to pre-seal thassos mosaiz tile. The tiles are polished and have a mesh backing. What is a good presealer brand, can i use a sponge, how many layers and how many days should i let it set before installing, and should i preseal the 4 sides where the grout lays. Thank you for all your help.
ms.nancy
msn is offline   Reply With Quote
Old 06-22-2018, 07:51 PM   #2
Hi Nancy, welcome. I've used Miracle 511 many times and it seems to work fine. I would wipe it on the surface with a rag and buff it with a separate rag, wiping off the excess. Avoid getting it on the edges but it's not the end of the world if it runs down the edges in a spot or two.
Thassos mosaic advice please phd Tile Forum/Advice Board 2 03-22-2017 08:59 PM
Sealing grouted mosaic tile WildLuvRebel Cleaning, Restoration and Sealing 1 08-12-2013 09:38 PM
Sealing unglazed porcelain tile mosaic table nicole mull Cleaning, Restoration and Sealing 0 07-06-2010 10:58 AM
Sealing Absolute Black Granite and White Thassos Marble uncleargyle Tile Forum/Advice Board 1 11-18-2007 05:23 PM
Sealing marble mosaic tile in bathroom duffinson Cleaning, Restoration and Sealing 0 10-31-2005 10:29 PM
Found usc_block_11 empty, added this: [CODE] [/CODE]
