Found usc_block_11 empty, added this: [CODE] [/CODE]
Old 06-21-2018, 10:04 PM   #31
Mr_Stop
Home Remodeler
I just found out about the JM GoBoard today. I have been using KerdiBoard on my last two shower installs. However, the price and loosing the labor and build-up of the banding has me intrigued.
Question
How are you handling the shower pan with the GoBoard? For example, are you using a liner, or are you using a membrane?
Brad
Mr_Stop is offline   Reply With Quote
Old 06-22-2018, 01:25 PM   #32
Northmen
USG Foam Shower Tray
I'm using GoBoard on the walls and then I'll be dropping in a USG foam shower system tray and curb on the slab.
I plan on applying the USG membrane over the tray and where the tray transitions into the GoBoard.
Steve
Northmen is offline   Reply With Quote
Old 06-22-2018, 05:02 PM   #33
smifwal
Not sure what you are paying for the durock brand screws. I got some of these based on a something I saw that Dave gobis had posted. $34.09/5lbs
Old 06-22-2018, 08:37 PM   #34
DownEastGC
Carpenter
DownEastGC's Avatar
Originally Posted by Mr Stop
Question
I've only used GoBoard with acrylic/cast iron tubs or shower pans. No tile pans, yet.
If I were to do a tile pan with it, I'd probably do a Kerdi/Goboard hybrid of sorts. Kerdi pan & drain, goboard walls.
Just noticed what Northmen had mentioned. USG pan/membrane, Goboard walls. Slick.
Good lookin out, thanks! Always good to have options. I'm not sure what this container weighs in at. They sell them listed by the qty, not weight.
This 350pcs jar I pay $18.30+ tax.
Chris
GC Specializing in Remo/Reno
DownEastGC is offline   Reply With Quote
Old 06-22-2018, 09:30 PM   #35
smifwal
I will see if my rep knows what they weigh. I am looking at the install sheet. How does this not make a deviation from plane
Old 06-26-2018, 05:17 AM   #36
Northmen
Geniune GoBoard Fastners
Using genuine GoBoard screws cuts down on the number of screws needed.
Spacing is every 8 inches with Goboard screws VS every 6 inches with standard cement board screws. GoBoard screws have an over-sized head for better holding power
$38 for 5 pounds.
Steve
Moisture sandwich CWMCPA Tile Forum/Advice Board 5 06-30-2016 02:26 PM
Moisture Sandwich? Brad Denny Professionals' Hangout 69 12-08-2013 05:14 PM
Moisture Sandwich??? JoeBoxer Tile Forum/Advice Board 12 07-26-2010 01:52 PM
