Anxiety over water test
OK so I did my watertest of my kerdi. I wish I wasn't such a neurotic freak, but now I am concerned if I did it right.
I pluged the drain. Then put a little bit of water in the drain to make sure the plug was water tight. after a 1/2 hour to ensure that the plug was secure I filled the floor with water. Here is my concern. I filled it to the point where the water went up the walls about a 1/2 inch. In hindsight (which I always do, I can't leave well enough alone), perhaps I should have filled it higher? Understand that when I installed the kerdi I did it like in the video. Kerdi band on the joints. Then walls, then floor. So when I put the water in to test the floor and wall joints were covered with water. the water didn't move. I tested it by placing a measuring stick down into the center of the drain. The water never moved below the line.
Can I rest now. Please someone give me an "amen."
Part of me can't believe that I did it right.
Finally, I have to ask if that is the most extreme situation that the kerdi membrane will ever be under. I mean once the shower is tiled, how much water actually seeps through? I can't imagine that there will ever be that much water actually on the kerdi membrane ever again. At least as long as the tile stays on the walls and floors.
Thanks if advance for anyone who can ease my mind.
Father of 3 Gs
