Unread 02-13-2016, 05:40 PM   #1
tileguynky
Resin Glass Blade and cold weather
Bought one of Pearl Abrasives new Resin Glass blades. Sure looked sharp at the demo and online. Finally broke down and bought one last month. Put it on my little wetsaw and set it on the truck. Well it is winter here, and it's been colder than usual. Pulled it out Friday and set it up to make cuts. Less than 10 cuts and the resin debonded from the saw. First, new blade is on the way from Pearl. The rep wasn't really sure if there was any testing done to see how it holds up when being stored in cold climate. Neither the box truck or the little garage are heated. So just a heads up to those who use might be using one in cold temps. Friday morning was 8 degrees without windchill. Here's a pic of the blade.
Unread 02-13-2016, 07:09 PM   #2
Tiger Mountain Tile Inc
I've had my eye on that blade too. It'll be interesting to know if it's the cold weather or just a bad blade.
Unread 02-13-2016, 10:24 PM   #3
dhagin
Wow! That could be bad.
dana
Unread 02-15-2016, 08:20 AM   #4
Sprung831
Tile Tool Guy
Sprung831's Avatar
If you do some more research on resin bond blades, you'll find that this problem is pretty common actually. One of the biggest culprits is RPM. Be VERY careful with this. Make sure that your motor rpm is not above what the blade is rated for. I for one when testing any resin bond blade, wear a full face shield because of this exact issue.
Steve Sprung
Technical Manager
Midwest Trade Tool
www.tiletools.com
Sprung831 is offline   Reply With Quote
Unread 02-16-2016, 06:11 AM   #5
tileguynky
Max RPM stated on the blade, 3700. RPM of Felker TM-75 is 3300 rpm. Just sharing for anybody that is curious.
For your cold weather tiling needs... Brad Denny Professionals' Hangout 17 01-05-2008 05:21 PM
Cold weather installations??? thuffner3 Professionals' Hangout 13 11-28-2007 09:32 PM
Thinset for cold weather? tileguy88 Professionals' Hangout 8 10-26-2006 08:09 PM
Cold Weather utdiy Tile Forum/Advice Board 3 02-18-2005 03:38 PM
Tile in cold weather marcnkelly Tile Forum/Advice Board 3 10-28-2003 05:45 PM
